Wideband with OEM ECM????
  • HayesPerformance
    • 783
    Hey Everyone,
    I was just wondering IF you can run a wideband O2 with a stock ECM? and if so WOULD the stock ECM fully benifit from using one? The reason I ask is cause I thought that a wideband O2 is only used with a EFI system made to handle one OR just as a AFR tuning tool.
    Thanks.
    David
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    with Code 59 you can.. it has integrated wideband control. it runs on the '7730 and '7749 ecm
    as for other masks, no.
    • TurboGTU
      • 453
      Usualy used as a tunning tool, but you have to mess with computer code if you wanto intergrated into the computer. Code59 is a good code if going boost.
        you can run it without boost as well... you just won't use most of the VE table.. lol
        • HayesPerformance
          • 783
          So do I just download this to my Tuner Pro RT?
          Does this work with non-boosted engines?
          Will this benfit my factory ECM?
          1991 Grand Prix STE
          3.4 DOHC
          1 of 792 Produced
          Extensive Mods Done
          1991 Lumina Z34
          3.4 DOHC
          Getrag 284 5spd
          1 of 30
          • torq455
            If I only had money!!!
            • 1615
            good question. do tell!
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
              If you don't have some wild engine configuration i doubt it's worth the effort. they put it in code 59 because guys would be running like 30 PSI of boost with god knows what else going on.. they would need more accurate o2 readings VS something alot more mild. To run it you would have to start from scratch and re-tune the engine, that would take several weeks of work.
              Yes, like i said before.. it will work with non-boosted engines.
              • Guest
                I enabled the WBO2 fueling in $59 briefly about a week ago, just to see how it worked, I did this at idle and just off, without driving the car, looked to update very quickly and control the AFR very quickly as well. My tune still isn't close enough to enable it full time, just yet.
