service engine soon codes
  • cold_surfer
    • Jul 2009
    • 16
    the system is throwing a code to light up the "service engine soon" idiot liht while driving. If I pull off the road, shut off car, insert paper clip to jump a&b (upper right two pins) then click on ignition to run -- nothing happens but the service light glows steady and no flashing. also -- radiator fan turns on at the same time.
    any ideas of how to find that Code?? jump different pins?
    thanks, CS
  • cold_surfer
    • Jul 2009
    • 16
    oh yeah -- 1993 firebird V6 3.4L all stock except K&N filter... automatic.
      • 9189
      I don't think you can pull codes with a paperclip on a 93 Firebird due to the ECM. I know the functionality was removed in 94 for the FWD cars due to the new OBD-1.5 setup, and I think the f-bodies went to that system in 93... Best bet would be to take it to AutoZone and get them to pull the codes for free.
      • tkoforpresident
        Max
        • Feb 2009
        • 710
        paperclip method won't work like brad said, and every time i went to autozone/advanced auto they didn't have the correct scanner for our cars, which is hard to believe because it's really just obd-1 (the 95 year has obd1 with an obd2 port which can confuse people)
        i ended up buying my own scanner for 150$ actron 9150 IIRC and has been able to scan my 93 bird and every other car i own right now.
        93 Firebird 3.4
        • [ChaosweaveR]
          4x4 status FTW!
          • Dec 2009
          • 136
          I work for them, and they do sell the very simplistic code readers, but nothing like what you bought. Honestly, since a lot of people that work at Autozones aren't totally car savvy and take the time to realize or understand the difference between OBDI and OBDII, it's just easier to know if the car is 96+ and just pull troublecodes. Sadly, since we don't have the equipment, my store has turned away a lot of people needing codes from pre-96 cars.
          -Chris-
          03 Black GAGT Sedan
          MODS:
          MP Racing CAI / Magnaflow High Flow Catalytic Converter / Flowmaster 80 series w/glasspack resonator
          Front STB / MSD Ignition: 8.5mm wires & blaster coils / SOME BIG GODDAMNED MUDFLAPS
          And some other stuff to make it look pretty. :D
          • Weatheralls Auto
            Spinning out of control
            • Dec 2009
            • 536
            As of April 2
            Engine: 2006 SV6 3500 LX9
            Trans: 2002 Getrag F23 5speed
            Injectors: #36 GTPs
            TB: 65mm TCE
            Maf: 1999 3400 Montana.
            Beverages: Ice Cold CANADIAN.
            • tkoforpresident
              Max
              • Feb 2009
              • 710
              Originally posted by planethax View Post
              didn't realize this was an old thread. I think i found it in the "new posts" section lol
              93 Firebird 3.4
