Tuning a 93 3.4 Firebird
    if you know there aren't going to be any last minute changes, i don't see why not....
    • 60dgrzbelow0
      "Yes... I AM IRONMAN..."
      • Mar 2009
      • 1344
      #197
      Originally posted by tkoforpresident View Post
      yeah, what isaac said ^^
      the less sensors used, the less that can go bad so i like it.
      Technically your right Bob, and I have no idea if it is the camshaft alone and not a sensor or two gone haywire causing the vehicle to stall out and idle irradically. But like robert mentioned before, we can assume that once a radical cam is installed there will be radical results. Remember, my car ran FINE before the cam install and has developed driveability issues directly after the new radical cam was installed.
      I think you should just wait and see how much tuning will help out
      Forced: Harness looks great imo, what is that black wrap around the wiring?
      I'll be patient... I promise... But as Isaac Said ... The "Neo" Sensor (The One...The Triple X Sensor...or 7X) in this case is the very "1" I would be very curious to know will be rock-solid when John's Goody Box and contents arrive in Buffalo...and you install all that cool 'Lectronic Cabling and the Lumina ECM/PCM have found a home under the FB's Hood. It should be okay..........But..............
      • tkoforpresident
        Max
        • Feb 2009
        • 710
        #198
        Any ideas guys on how i'm gonna mount the lumina pcm in my firebird??
        IIRC it's a square metal box right? i don't want that thing sliding around. Maybe i should use bondo....
        lol any thoughts?
        Bob: I'm right there with you. My hopes are that if a sensor IS bad and not being picked up by the actron scanner than maybe it will be obvious through data logging that a sensor is not up to snuff.
        93 Firebird 3.4
          Live life 3.7mi at a time
          • 4555
          #199
          Max, if you take the plastic bracket off your current PCM, the Lumina ECM will slide right in it, and you mount it just like you would your stock PCM ...
          Her's one loosely bolted in place...
          The Lumina just mounts to the sides instead. I'm not sure if I have the nuts on the ECM I'm sending you, but you can find them at any hardware store.
          • tkoforpresident
            Max
            • Feb 2009
            • 710
            #200
            no nuts?? .... cheapskate
            lol j/k
            Thats awesome news though about the bracket. You can hardly tell the pcm has been changed out.
            93 Firebird 3.4
              • 4555
              #201
              Yeah unfortunately when I get the ECM's, they don't always have the mounting nuts on them
              I try to make things look like they belong there
                haha, very funny, it works though...
                the RWD tray is MUCH easier to deal with than the one in the MC...
                • tkoforpresident
                  Max
                  • Feb 2009
                  • 710
                  #203
                  lol Believe it or not, i'm of the very same mind set. But John refuses to let me compromise on aesthetics.
                  93 Firebird 3.4
                  • tkoforpresident
                    Max
                    • Feb 2009
                    • 710
                    #204
                    So who wants to go over data logging basics with me real quick?
                    93 Firebird 3.4
                      using V4 or V5?
                      • tkoforpresident
                        Max
                        • Feb 2009
                        • 710
                        #206
                        ummmm
                        Tuner Pro RT?
                        93 Firebird 3.4
                          we know that. which version? V4 or V5?
                          • tkoforpresident
                            Max
                            • Feb 2009
                            • 710
                            #208
                            sry....
                            Version 4.14
                            93 Firebird 3.4
                              funny, isaac and i were just predicting this situation no more than 6 hours ago....
                              know how to load your ADS?
                              set the correct port for the ALDL cable?
                              • tkoforpresident
                                Max
                                • Feb 2009
                                • 710
                                #210
                                lol what's that ^ supposed to mean?
                                umm
                                i don't know how to do either... but if i do it once i'll never forget.
                                93 Firebird 3.4
