Tuning a 93 3.4 Firebird
    honestly, i would be using V5 due to the differences in how data can be manipulated....
    but with V4, i wouldn't split the data up.
    • tkoforpresident
      Max
      • Feb 2009
      • 710
      #377
      i'm assuming i have to buy V5?
      How does V5 make things easier?
      93 Firebird 3.4
        have to buy? no, you just get the 10 second nag. i believe if you get in touch with mark, he has a reduced price for people that have bought previous versions...
        how does it make it easier: V5 is basically an upgraded version of the scannerpro engine, except now it's stable and is VERY customizeable, allowing things that V4 never could.
        lucky for you, i play with A1 all the time, so i have a decent dash and features for it already designed and tested.
        my autotuning stuff is EXTREMELY simplified. all you have to do is literally copy the VE table, the BLM and INT history( though i am working on a version that only needs one table) and then it does everything for you instantly. just copy the corrected main and idle tables into TP, click save, burn and go.
        • tkoforpresident
          Max
          • Feb 2009
          • 710
          #379
          well i've never actually purchased an older version... i don't mind paying for it. where can i get tp5??
          93 Firebird 3.4
            #380
            www.mcdonalds.com is the only place.... Where do you think? :P http://tunerpro.net/beta/tpbeta.htm
            • tkoforpresident
              Max
              • Feb 2009
              • 710
              #381
              hahah well i think i tried looking at that site and it wanted i think a 39$ payment for the beta version.
              93 Firebird 3.4
                it says beta, but i've been involved with it since it was a closed alpha...
                download it, try it out, you'll probably like it more than V4... i'll send you my A1 ADX...
                • tkoforpresident
                  Max
                  • Feb 2009
                  • 710
                  #383
                  ok i'll download it.
                  and by ADX you mean what??
                  is that another term for .xdf or .ads?
                  btw, tuner pro's website wants me to pay for V5. Are you sure there is a free way to download it?
                  93 Firebird 3.4
                    you're doing it wrong? and ADX is the new file format for datastream definitions, it replaces the ADS...
                    direct download of the newest version...
                    • tkoforpresident
                      Max
                      • Feb 2009
                      • 710
                      #385
                      gotcha, so ADS is now ADX.
                      just downloaded TP, thanks.
                      I'll take a look at the VE tables in V5. Will it be easy enough for me to adjust using fuel trim or will you have to go over it with me once?
                      93 Firebird 3.4
                        with V5, fueltrim in unnecessary. tunerpro determines what corrections are necessary.
                        • tkoforpresident
                          Max
                          • Feb 2009
                          • 710
                          #387
                          so whats the procedure then? Will i have to datalog again using V5 to get data for my adjustments or is the datalog i have right now adequate?
                          93 Firebird 3.4
                            you'll need a V5 log to use the simpler setup...
                            procedure is:
                            copy old VE table into spreadsheet
                            copy BLM and INT histograms into spreadsheet
                            copy new main and idle VE tables into tunerpro
                            press save
                            burn
                            somewhere along the way, you'll want to manually check to see that no bad packets got sent through the ALDL and give some crazy INT number... when mine has a transmission error, it's almost always 800RPM at 100kPa.... i really don't know why though. it's something i'll have to ask mark when he's not busy.
                            • tkoforpresident
                              Max
                              • Feb 2009
                              • 710
                              #389
                              well i'm working on my VE tables (any surprise there?) but i'm wondering if some of the adjustments (i.e. .424) are just a little too radical. Believe you me this car is running pig rich, but i'd rather not have an extremely lean condition where my car decides to go....
                              Kaboom!!
                              Either way... i'm making those changes then we'll see if it's as rich as last time when it set off an 02 Rich error code and seemed to more or less run like poo poo.
                              93 Firebird 3.4
                                i wouldn't change more than 20% fuel at a time in a situation like this... so anything that says .799 or less, just see it as .800 and go from there.
