122749 tuning and data logging
  • neo71665
    its this big
    • Oct 2005
    • 361
    I'm really interested into trying to tune and data log my 87 blazer. I'm a complete noob at this and the more a research the more I think I'm confused. I know I have a 122749 ECM and have been told I need to swap it out but I haven't been told why or what is better. I'm still running the TBI but might be interested in swapping to a 2.8 f-body MPFI if its easy enough. I really don't wanna rewire the entire truck for the extra injectors and what it has is working fine.
    This is the best pin out for my ECM I can find
    A1 Green/white Fuel pump relay
    A2 Dark brown A/C clutch control
    A3 ***not used***
    A4 Gray EGR control
    A5 Brown/white Service Engine Soon light
    A6 Pink/black 12V switched power
    A7 Tan/black TCC or shift light
    A8 Orange/green Serial data at ALDL
    A9 White/black Diagnostic input at ALDL
    A10 Brown VSS input
    A11 Purple MAP ground
    A12 Black/white System ground
    B1 Orange Battery 12V
    B2 Tan/white Fuel pump signal
    B3 Black/red HEI ignition module ground
    B4 ***not used***
    B5 Purple/white HEI reference
    B6 ***not used***
    B7 Black ESC signal
    B8 Dark green A/C signal
    B9 Brown EGR switch signal
    B10 Orange/black Park/neutral switch
    B11 ***not used***
    B12 ***not used***
    C1 Pink/black EAC solenoid (Federal)
    C2 Brown EAC solenoid (California)
    C3 Green/black IAC Coil B low
    C4 Green/white IAC Coil B high
    C5 Blue/white IAC Coil A high
    C6 Blue/black IAC Coil A low
    C7 ***not used***
    C8 ***not used***
    C9 Purple/white Crank input
    C10 Yellow CTS signal
    C11 Light green MAP signal
    C12 Dark blue/white ETM
    C13 Dark blue TPS signal
    C14 Gray 5V reference (MAP, TPS)
    C15 ***not used***
    C16 Orange Battery 12V
    D1 Tan/white System ground
    D2 Black MAP ground
    D3 ***not used***
    D4 White EST
    D5 Tan/black EST bypass
    D6 Tan Oxygen sensor ground
    D7 Purple Oxygen sensor signal
    D8 ***not used***
    D9 ***not used***
    D10 ***not used***
    D11 ***not used***
    D12 ***not used***
    D13 ***not used***
    D14 Light green Injector drive B
    D15 ***not used***
    D16 Light blue Injector drive A
    I know for data logging I'll need the cable and I'm looking to buy a new laptop. What programs will run with the windows7 OS?
    If I need to swap to a newer computer for the TBI what do I need to look for and do you have a pin out for it if I have to move wires around?
    87 3.4 4x4 blazer
    if you need diagrams, i got them. i'm assuming you want to use a ECM that uses the 8192 datastream instead of the 160 that most TBIs got?
    and did you mean 1227749? that happens to be the syclone/typhoon ECM...
    as far as programs to log: tunerpro RT works great with vista, no reason why it wouldn't work with Win7...
    EDIT: rockauto says you should have a 1227429 from the factory...
    • neo71665
      its this big
      • Oct 2005
      • 361
      duh, I'm an idiot. I meant 1227429. It seems the info I find points to it being only half hacked and thats why I "need" to swap to a newer ECM out of a 88-93 s10 with a 2.8 ecm 1228062
      A2 ***not used***
      A3 Green/yellow Canister purge control (not used)
      A4 Gray/red EGR control
      A8 Orange Serial data at ALDL
      A10 Brown VSS input
      B2 Brown Fuel pump signal
      B4 ***not used***
      B6 ***not used***
      B7 Black ESC signal
      B9 Blue EGR temperature sensor (not used?)
      B11 ***not used***
      B12 ***not used***
      C1 Black/pink AIR divert solenoid (not used?)
      C2 Brown AIR switch solenoid
      C7 Light blue 4th gear (not used?)
      C8 ***not used***
      C12 ***not used***
      C15 Light green Injector B (not used?)
      D1 Black/white System ground
      D2 Black TPS, CTS ground
      D3 ***not used***
      D4 White EST
      D8 ***not used***
      D9 ***not used***
      D10 ***not used***
      D11 ***not used***
      D12 ***not used***
      D13 ***not used***
      D15 Light blue Injector drive A (not used?)
      87 3.4 4x4 blazer
      • Joseph Upson
        Try these guys, they've been around longer than tunerpro and are who I started with.
          here's an idea of what you can play with when you have an 8062 and a 7429(using tunerpro anyway...)... the ACKU is the 7429, the ANJF is a 8062.
          • neo71665
            its this big
            • Oct 2005
            • 361
            Thanks alot, I know it seems like explaining it to a 1st grader
            87 3.4 4x4 blazer
              after a while, i just accepted the fact that i was studying this a LOT more than the average person does, so i actually expect it...
