mapsenor?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    mapsenor?
    will the map sensor on my 3500 be compatible with a 7730? it's a 3 wire unit, but about 1/3 of the size of the other obd1 map sensors.
    Thanks-
    Eric.
    The newer style sensors are supposed to work in place of the older ones just fine from what I've read.
    Sent from my SPH-M820-BST using Tapatalk
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      Awesome, they're much smaller, so they also look alot better!
        Agreed. I was going to use that style when I do the intake swap on the 92.
          Yep, they work just fine.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            sweet! Now I just need to find a 3 bar off a ZR1...
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              Next Question, does anyone make a 5 wire maf suitable for my LX9?
              • Z3500
                • Jul 2011
                • 42
                Not sure why you would need a MAF sensor when you are using the map?
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  I'm looking into a modded obd1 ECM that uses maf and map.
