deceleration enleanment
  • LZeppelin513
    • 225
    This is a stupid question but I'm not really seeing a change. To take more fuel out during decel enlean do I decrease the values? I'm going rich right as the throttle lifts but then makes its way lean after a second or so (this is usually around when decel enlean is no longer active). I have been messing with it but can't get it to lean out cutting negative d tps.
    which specific values are you messing with?
    • LZeppelin513
      • 225
      DE factor VS negative D-TPS
      DE factor VS coolant temp
        may want to play with the F35 table.... that's the one that determines the "time profile" for DE.
        • LZeppelin513
          • 225
          Well I have just been trying to make global DE changes because DE is not taking enough fuel out anywhere. What I was trying to describe earlier is that fuel will finally go from rich to stoich about a second or so after letting off the throttle. DE only lasts a second or so and during that second (the entire duration of DE activity) fuel is rich.
          In F35 do I decrease the values to take out fuel? I haven't messed with that table yet but with the tables I was playing with I wasn't getting a clear result.
            in that table, larger numbers = larger amounts of fuel removed.
            • LZeppelin513
              • 225
              OK thanks, and after it gets to the last injection, that value is used the remainder of the time in DE, correct?
                correct. the code increments the injection counter up to 16 and if it attempts to go past it, it will limit to 16 and continue.
                BTW, 16 DE injections, at whatever RPM (RPM/60 = RPS, and with one injection per revolution, divide with 16 to create max time)
                1000RPM = .96 seconds
                2000RPM = .48 seconds
                3000RPM = .32 seconds
                4000RPM = .24 seconds
                so, should you be beyond that time , you're always going to be using the last value in that table assuming DE is still active.
