First test and tune at the drag strip is this weekend. Going with a buddy running an RX7. Trying to work on the tune at the last minute here after having all winter to do so. Car has some sort of aftermarket turbo on it and was hitting the 8.32 psi overboost fuel cutoff (code 31) on the track when I went last year when we went. Could only go 15.4 with the car cutting off fuel like that throughout the run.
Editing the boost tables ($8f) and the overboost cutoff tonight and it won't let me enter a value higher than 10.61 psi (208.80 kpa). If I enter a higher value and save the scalor (is this the right term?) tunerpro automatically backs it down to 10.61 psi. Please tell me this isn't some maximum allowable value. The boost tables allow for more desired boost than that! And this turbo will make it too. I currently have drafted it to maxing out at 12.20 psi on the top end. If 10.61 it is some max overboost value, is there some way around it to allow higher boost?
