OBDII conversion in progress.
  • Rhedalert
    Dr. Feelgood
    • 1574
    Valve timing- Int -7 BTDC, 37 ABDC; Exh 41BBDC, -3 ATDC
    Lobe lift: Int: .288 , exh: .288
    LSA: 112
    Dur@.050: Int: 210, Exh: 218
    Adv Dur: Int: 265, Exh: 273
    I'm still waiting on my powertuner. They're a little slow, but Im in a hurry to get this engine under control, at idle at least.
    Brian
    3400 SFI V6, 4T60e
      So your saying I should order mine now if I want to see it in like 2 months... haha.
      Do you have a pinout chart for the 97 cutlass ecm so I can compare it to a 96 beretta. just the body style alone may have different pinouts. My ecm is at home so I dont know the number on it right now.
      And that cam has slightly longer duration compared to a stage 1 but less lift... I wonder how my stage 1 cam will run on a stock tune...
      • Darin
        • May 2006
        • 259
        Here is the pinouts for a 97 cutlass, It will probably load slow.
        Any particular GM vehicles you would like, I will add them on request.
        1999 Grand Prix SE 3100
        1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
        1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
        • Rhedalert
          Dr. Feelgood
          • 1574
          if it's anything like my car's running, it won't start easy when cold, and it'll idle like hell (major lope) of course believe it or not, my OBD1 3100 PCM handled this engine better at idle than the OBD2 3400 PCM. So it really depends.
          Yes, I'd order the DHP now if I were you.
          I think if the PCM is the same, then the pinouts *should* be the same too. So far I have run w-body, H-body and minivan PCM's (of '96-97) on the same harness with nothing to modify.
          I just did a quick search on car-part.com for a '96 Beretta PCM, and everything GM's are coming up, so they are interchangeable.
          Brian
          3400 SFI V6, 4T60e
            I may go to the yard this weekend I'll see what I can come up with.
            • blackbombshell95
              Kaiō-ken X 10
              • Jun 2004
              • 1386
              #21
              I hear the 98 to 99 monte/lumina computer/wiring harnesses is the best way to go. Infact I'm having Brian Teel wire my 95 Grand Prix 3100 4t60e harness to a 98/99 monte/lumina harness.
              It can be done and he has done it. Check out www.motorswap.org. He charges $300 to wire the 2 harnesses to together. He is also rewiring my injectors for l67 injectors.
              02 GTP - 90* > Failboat
              www.blackbombshell95.com
              • Rhedalert
                Dr. Feelgood
                • 1574
                #22
                what two harnesses? You mean interior harness to exterior harness?
                Brian
                3400 SFI V6, 4T60e
                • gboogie99
                  they still can't catch me
                  • Nov 2005
                  • 348
                  #23
                  darin, got something for a 95 cutlass ciera?
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    #24
                    Computer harnesses
                    • gboogie99
                      • Nov 2005
                      • 348
                      #25
                      you mean to hook up a newer computer to the old harness or what?
                      • Darin
                        • May 2006
                        • 259
                        #26
                        What are you specifically looking for? I think all I currently have is 3800 stuff, I'll have to look, Corey (blackBombShell) bought the last of my 3100 obdII stuff.
                        • gboogie99
                          • Nov 2005
                          • 348
                          #27
                          well if there is some kind of adapter to use a 95 obd 1.5 harness on a 96 computer, thats what I would like to get.
                          • Azrael
                            Accelerating uphill in OD
                            • Apr 2005
                            • 763
                            #28
                            A wiring harness adapter would be cool but you'd still have to add some new wiring for things like the MAF sensor, which were't used with OBD 1.5.
                            I'm trying to put together a sort of check list of things needed for such a swap. Might make a for a good article on this site. But I'll leave a proper DIY guide to someone more experienced in the matter.
                            1995 Grand Am SE
                            • Rhedalert
                              Dr. Feelgood
                              • 1574
                              #29
                              I've been meaning to do that too.
                              Brian
                              3400 SFI V6, 4T60e
                                Well It's all done and it runs, And I didn't even remove my dash harness...
                                I still have a OBDI.5 com port on the drivers side...
                                Well this is how she sits right now.
                                I'll be driving it to work tomorrow so I'll let you know how that goes.
                                Extra Parts... Fuel gauge went bad and leaked the liquid out of it so I guess I'm gonna scrap it. I'll just stick to a tester to set my pressure, I could never see this gauge anyways. NOS stuff will also get cleaned up and then put back in.
                                Function over Form right now... I'll clean up the wiring mess now that I know it runs.
                                Power tuner FTW!!!
                                Proof it runs...
                                Running Vid... 4mb video
