What computer related problems would I have and how would I correct them?
282 on OBD2 3.4x?
Both sites dont say you can use their software on a pre 97 grand prix. My cars actually a 95 but I'm upgrading to obd2 and a 96 motor. Think the hp tuners software will work with my car?
You will need to upgrade to OBDII. You should be able to edit the 96 ECM at least with DHP I know but a 97 ECM is better as it has double the memory and more options are opened up for you to edit.sigpic
ECM is sometimes called the PCM. engine/powertrain control module. Since it controls the transmission too, hence the powertrain.sigpic
Yeah they are the car's computer. BTW if you keep your OBD1.5 PCM/ECM and go to manual it will run and you won't have any check engine lights AFAIK, but you will get a little surging idle due to the automatic code. It's OBDII that will set lots of codes for trans slipping etc.sigpic
Well my current obd1.5 engine has a blown headgasket along with many other problems caused by the headgasket. If I'm getting a new motor I might as well get the obd2 version.
Also is there anything one can do over the other? And how much$ am I looking at?Last edited by gpchris; 11-24-2007, 10:21 PM.
