Lean At Wot Help!, I don't understand WHY
  • PCGUY112887
    • Feb 2006
    • 1067
    When I get on it, PE kicks in and my wideband shows rich (12-13AFR) but as soon as I go WOT anytime my wideband shows 14-15AFR.
    The narrowband O2 data in the scan here is all over the place, I don't have a clue what it's doing.
    When I first got this motor going at WOT the wideband would show crazy lean (off the scale) but after upping MAF (a LOT) at higher hz ranges it got to 14-15 at WOT.
    I'm afraid to just keep adding to the MAF it doesn't seem right. Right now at WOT I can only pull about 8500hz on the MAF but I think it's due to having a totally stock airbox... hell I think my engine is outflowing the little slit in my airbox that feeds the engine.
    But I still don't understand why I'm LEAN. Help?
    Get a new domain name for your startup. Quick and professional service. Seamless domain transfers.
    SpudFiles
    Theopia
    Enjoy life online.
  • sprucegagt
    Old School KI
    • May 2005
    • 703
    Have you done any VE tuning recently? What is your PE enable point?
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
    • PCGUY112887
      • Feb 2006
      • 1067
      My only VE tune was done in the very beginning of me starting the car, so no. I have the VE table for a stock 3500 now (I'm based off a 97 3400 VE table right now) so I have considered changing to the 3500 table then redoing my VE.
      Here is a picture to show my PE Enable points.
      SpudFiles
      Theopia
      Enjoy life online.
      • sprucegagt
        Old School KI
        • May 2005
        • 703
        Has this problem always been there or is it something new? What BIN file are you using?
        • PCGUY112887
          • Feb 2006
          • 1067
          Yes this has always been there, and I am using a 97 Venture BIN file.
          SpudFiles
          Theopia
          Enjoy life online.
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            Then I'm thinking you have a problem with the PE_Delay table. Powrtuner won't be able to access it, but Eddie can. PM him on the DHP forums and he may be able to help you. Also tell him your problem, he may know of something else you need to fix.
