Really Need a Timing Table
  • Impala3400
    • Sep 2008
    • 10
    Yeah sorry for not listing mods, i have a Catless Downpipe, Catback and a 3" CAI
    My BIN is attached
    Heres is a Scan of all of first and into a little bit of second
    • geldartb
      The Situation
      • May 2004
      • 1994
      why do you have to screen names or is this two diff people
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • Impala3400
        • Sep 2008
        • 10
        my other one is havin problems, i reset my password and it dosnt send me the link to my email for the new one
        • Impala3400
          • Sep 2008
          • 10
          So i scanned my car again today and things make no sense... In first gear i get almost zero knock, in third gear i get almost zero knock, and in 4th i get zero knock, yet 2nd gear has 6-7 degrees of knock.. its the only gear with the problem and my LTFT are dialed right in at 0 with 02s in the 860mv range, sparks right around 23 - 24*
          • geldartb
            The Situation
            • May 2004
            • 1994
            when does the knock happen. what rpm, is it right when it changes into 2nd gear or somewhere throughout 2nd.
            i get a little knock going into 2nd but mines like a degree or 2 and its from the solid mount i got.
            99 Grand Am GT
            • Impala3400
              • Sep 2008
              • 10
              #21
              i have a scan listed in the post with my bin, it happens at the top of second 4k+
              • geldartb
                The Situation
                • May 2004
                • 1994
                #22
                your files are gone now.
                how do your plugs look, try running some seafoam through the top-end to clean some of the crap out.
                does the knock happen every time
                99 Grand Am GT
                • Impala3400
                  • Sep 2008
                  • 10
                  #23
                  its pretty consistent, look at my scan
                  • sprucegagt
                    Old School KI
                    • May 2005
                    • 703
                    #24
                    Off the bat you have a couple problems.
                    1. PE Delay is active. When at WOT you should immediately be in FTC 3, not having to wait a couple seconds. Good luck in getting this fixed, PT won't touch it and I don't think HPT will either.
                    2. LTFT must be at 0 anytime your at WOT. ANYTHING LESS IS UNACCEPTABLE. During your entire WOT run you were pulling about 3.9% of fuel from your commanded AFR settings.
                    3. When you go WOT, stay at WOT or get completely out of the throttle. Right at your 1-2 shift you backed out to about 3/4 throttle, then WOT again. This screwed up the commanded AFR fueling. Instead of staying rich the entire run, it tried to lean out slightly then richen back up. This only aggravated your KR problem.
                    Your local OBDII moderator
                    2000 Grand Am GT w/ WOT parts
                    • Impala3400
                      • Sep 2008
                      • 10
                      #25
                      so i should scale my maf and try and lean things out to help teh LTFTs?
                      • sprucegagt
                        Old School KI
                        • May 2005
                        • 703
                        #26
                        In short, yes. But I think you haven't read this.
                        Please take the time to read it from beginning to end. It will get you started down the right path for tuning.
                        • Impala3400
                          • Sep 2008
                          • 10
                          #27
                          Aside from doing a VE tune i can just Scale the Maf and lower A/F ratio on PE?
                          • sprucegagt
                            Old School KI
                            • May 2005
                            • 703
                            #28
                            Yes.
                            • geldartb
                              The Situation
                              • May 2004
                              • 1994
                              #29
                              do your tune and whatnot on the stock file not the 1.5 bin you got from DHP, if you do it on the 1.5 you wont get the best results.
                              99 Grand Am GT
                              • Impala3400
                                • Sep 2008
                                • 10
                                #30
                                the 1.5 has nothing modified in fuel / spark anyway, its mostly tranny changes and little things like that
