Time for my OBD II this is the idea
    the a-body setup uses a MAF only.... and i released the starter pack for the 1.5 to 1 3100s that way it would all be ready to literally, burn and go.
    • Russell52
      • Jun 2007
      • 88
      #62
      I still gotta read how to read and burn,I know there is a certain "block"? That I have to read and write from.. I do have your starter pack,and after I get familiar with how things work,I will have the dohc computer.
        kind of an odd order to go about it, but you might open up a new path for those who like MAFs and don't want to pay for OBD2...
        if you use the BURN2, it does all of the math necessary, so don't worry about that. as long as you select the correct chip in the menu, then it will work just fine.
        • Russell52
          • Jun 2007
          • 88
          #64
          Good to know about burn2 as that is what I will have,I got that little adapter that,you use to read the original chip,hoefully I can read it,save it and edit it,then burn the changes I have made,hopefully lol.. Is there a place that details how to use Tp,and what everything in there means?
            HDR1 is what you use for reading the stock chip. works like a charm for me, i read the PROMs from the GP and the MC with no issues.
            if for some reason you can't get a good read off of it, i have one $1FA BIN already that would work for you.
            how to use TP: scattered all over the internet, i know there are a few recent threads here where we described a lot of it.
            explanation of all of the constants/flags/tables: ..............that might take a bit longer. every codemask uses different methods of fuel/spark calculation, the 94-95 3100 A-body ECM being a MAF setup, my knowledge of it is fairly limited, i prefer VE tables, so i learned that instead. but most of the principles the OBD2 guys base their tuning off of will apply.
              #66
              If you are going to DOHC setup, then just start with that... The A body setup does not use a MAP. So if the MAF takes a crap, so does your car...
                if the MAF dies, the ECM will resort to "default" tables, meaning it guesses as to the amount of air going in based on TPS and RPM. you can tune those tables to have it be somewhat close if the MAF dies, but they are meant to be conservative, not a replacement for true air metering.
                  #68
                  Right, but with like OBD2 where it can fall back to speed density, which you can tune too, it's going to be running rough... Especially if you had a modified or swapped engine...
                  • Russell52
                    • Jun 2007
                    • 88
                    #69
                    Looks as if I am going to have three computers,lol one under the hood,and two in the trunk..(backups)
                      i don't see why... the 9396 is built to last. most people have never had to change theirs over the life of a vehicle...
                      • Russell52
                        • Jun 2007
                        • 88
                        #71
                        oh I know,just being sarcastic :P,To wire all of these computers will give me something to do in spare time,And I will actually know all the differences,such as programming options. Something to do
                          well, i guess it's better to be bored AND productive...
                          but i'll say this now: DF (9396) is without a doubt, the most flexible option you'll come across... that can run our -e tranny anyway...
                          • DefEddie
                            • Aug 2009
                            • 194
                            #73
                            and the worst part is that it only includes one definition! for 2500 i could buy EVERY TC american OBD1 definition and still have $600 left over! and that covers damn near every GM vehicle from 82-95.
                            luckily the DIY community has dropped that cost significantly:
                            the definitions are obviously free
                            tunerpro is a pay-if-you-like setup with NO restrictions on the features
                            i've been pounding out tons of datalogging definitions lately
                            really, all you need to pay for is hardware.
                            BURN2 is ~85, G1 is like ~35, couple of chips for ~10-15, a high-quality ALDL cable for ~60, and you have everything necessary to tune whatever you need.
                            Just want to clarify real quick about Tunercats OBDII,
                            TCOBDII came out and was around $350 for the full setup and one definition,TC OBDII does NOT vin-lock at all.
                            JET bought the licensing and jacked the price up to $500,with two available VIN's you can program with the option of buying more VIN's/Licenses similar to HPT/EFILIVE.
                            Since John sold the licensing to Jet,he can no longer sell the product-but entered into a deal with moates I guess to keep it available (non VIN-locked).
                            To do that,it had to be a package deal I guess-hence the $2500 price tag.
                            For that you get the program,2 def files,unlimited reprograms/unlimited VINS,not to mention realtime licensing and the roadrunner.
                            JET screwed it all up,John at TC is awesome and sold/sells a heck of a product.
                              Sounds like Jet marketed it for a performance shop for that price, They did not consider the end user when they designed the package.
                              HPTuners is still the best way to go when it comes to individual car programming, unless you can find a DHP unit since those are fully unlocked with the current programming software. Granted supported Bins are limited to 05 or 06 years I think... No new stuff since that boat has stopped sailing.
                              I just went on their website and I was able to find the Jet DST for 499 specific to a 2000 Malibu just for an example. They seem to support 98+ models the most... I checked for a 98 Grand Am... Unfortunately does not appear to cover 1997 models.
                              I don't know where you guys got 2500 from
                                • 9191
                                #75
                                ?? I dunno, as that says for LS1s...
