wiring help needed!!
  • hookdonspeed
    • Jun 2007
    • 322
    im installing a 3500 into my fiero, and using a 98ecu, i have most of it figured out and compleated, so the first problem/question i have is the knock sensors...
    are the new knock sensors compatible with the 98ecu? if so, how would i wire them?
    looking at the diagram theres a twisted pair, then a 3rd wire thats labeled as "drain"
    im assuming if they are compatible the drian would be a pcm shared ground, the 1twisted would be 5v ref, and the other the signal wire?
    next question... are the cam sensors compatible from the 98ecu to the 06 engine?
    • 9189
    No the KS are not compatible.
    Not 100% on the cam sensor, but I am pretty sure that it will work.
    • gar70614
      • Oct 2008
      • 330
      im running a stock 05 3500 non vvt cam sensor with my swap and im running on 99 grand am pcm and modded harness. never had a problem, also running 3500 cts, and map
