IPC swap? 04 monte carlo
  • Joelfke
    • Mar 2010
    • 46
    May be the wrong part of the site for this but...
    I have an 04 monte carlo with a 3.4L v6. The instrument cluster is the boring regular common chevy one with the gas and temp split a tach and the speedo in the middle. I want to swap it out with an SS cluster that has more gauges and a nicer appearance IMO. Can I just swap it out and reprogram it to show the same mileage? I work at a chevy dealer so reprogramming is not an issue but no one seems to know if I can swap the cluster without any major issues.
    thanks
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    Step 1;
    Print out SI schematic for your current IPC, then find what year model etc of the IPC you want and print that one out.
    Then compare the two.
    (what Veh Year etc are you wanting to use? )
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • Joelfke
      • Mar 2010
      • 46
      i was looking to use an 03 or 04 SS IPC
