bin file 1998 F-body, 3.8L 5 speed
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    anyone have a bin file for a 1998 F-body, 3.8L 5 speed that they are willing to share?
    Thanks-
    Eric
    hmm.... i have autotragic versions for both camaro and firebird, but no manual...
    • onefastV6
      • Sep 2005
      • 880
      What is the VIN?
      Once I have this info I will see if I can help as I have a zip folder with about 300 .bin files.
      2000 Grand Am GT
      2011 Chevy Impala
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        unfortunately, I don't have a vin, I'm just wanting to break down some of the differences between an auto and manual bin files.
        • onefastV6
          • Sep 2005
          • 880
          I did a ebay search and found a manual 3.8L VIN for a 1998 Camaro = OSID 16268296
          I had a .bin in my list of files so I have attached it.
          2000 Grand Am GT
          2011 Chevy Impala
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            thanks, I didn't think of ebay to get a vin...
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              by chance do you have a bin for a J body-2.2 five speed too?
              Here's a vin...
              1G2JB12F237209990
              • onefastV6
                • Sep 2005
                • 880
                Here's a vin...
                1G2JB12F237209990
                Unfortunately I do not, all my files are mainly V6 files.
                2000 Grand Am GT
                2011 Chevy Impala
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  10-4 just figured I would ask.
                  • onefastV6
                    • Sep 2005
                    • 880
                    I did find a .bin for a 1998 2.4L sunfire with 5 speed if it helps.
                    2000 Grand Am GT
                    2011 Chevy Impala
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      thanks, I've run into one small problem now... tiny tuner and DHP don't recognize that bin... (I expected that!)
                      I'm looking at table "1st gear min RPM/Vehicle speed ratio" and "2nd gear min RPM/Vehicle speed ratio" I was thinking that this table should use data from the transmission's parent vehicle, in this case, a 2000 sunfire.
                      here's a screenshot from tiny tuner, the data inputted now, is the data for the F body.
                      • ga2001532
                        • Feb 2011
                        • 158
                        I never touched that in my bin.
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          I thought I had made a little headway on the above mentioned ratio, my thinking was that the ratio was simply Minimum RPM:engine speed, and that made sense until I looked st the second gear table, just to see it's identical to the first gear table...
                            it's used for N/V windowing. N being RPM, V being MPH. why you would need different "window" settings for a different MPH, i don't know, but it's how the PCM detects what gear a manual transmission vehicle is in, OBD1 applications do the same thing.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              but that's what's confusing me, the numbers should be linear, and they aren't. and 1st in this bin, is identical to 2nd, which doesn't line up either. it's not really that big of a deal though I guess.
