Is anyone running a OBD2 60* in speed density?
    That's in mine as well, and it's set for "use VE table" as a default. I know I disconnect the MAF to do a VE tune and that works just fine, but I've always had it run and idle way better when hooked back up to the maf. I've also had other issues when the MAF code was shut off.
    Maybe I just never ran it like that for long enough to iron out those problems though.
    • Bridgetown
      • Jan 2008
      • 174
      Tiny tuner? Do tell...
        I'm surprised you don't have this... WAY more tables than DHP.
        • Bridgetown
          • Jan 2008
          • 174
          Oh wow! I saw a thread a long time ago about it but I never really looked into it. I don't think it had gone public back then, and at the time I really wasn't that interested in tuning.
          Let me make sure I got this right, tiny tuner will edit, but it won't flash, correct?
          What are you guys using to flash? HPT is awfully expensive if all your doing is flashing with it.
          • onefastV6
            • Sep 2005
            • 880
            Correct, you can use Tiny Tuner to Edit, however you will need DHP PowrTuner or HPTuners hardware to flash the PCM.
            Over on Clupgp.com used PowrTuners come up quite often.
            2000 Grand Am GT
            2011 Chevy Impala
            • Z26-T
              • Apr 2008
              • 486
              #21
              or just simply disconnect the MAF sensor and it should jump to that.
              Thank you for stating that. I was going to recommend that, but since no one else did I was sure I was missing something.. haha.
                Well we weren't sure if that was a definite, him stating that flag along with that makes it a definite that it will be reverting to the VE table upon MAF failure.
                And yes Bridgetown, I will use TinyTuner to access tables that DHP doesn't have mapped and then I will just flash with DHP. Not often do I have to do that though.
                  Wasn't someone working on a way to tune OBD2 with Tunerpro recently?
                    you can make XDFs, i've started on one, have to do something about the checksum though, TP doesn't support the method, since it skips over the 4 bytes the checksum occupies and continues with the rest of the file.
                    as for pulling the calibration and reflashing, expect a solution REAL soon that doesn't involve HPT, DHP or any other current offering.
                    • Bridgetown
                      • Jan 2008
                      • 174
                      #25
                      Oh c'mon, details, details
                        that should wet your appetite.
                          Doesn't list pre 99 ECU's though for support...
                            yet. rapidly changing and support being added for anything that people can test to confirm it will function.
                              appears you still need to purchase some AVT unit though correct?
                              I wish someone would make software to work with the Tactrix device I use on my Subaru...
                                for now, yes. a cheaper(and easier to get ahold of) cable is in the works too.
