Found a useful link that you guys might like. I couldn't find a how-to so I thought I'd post the one I found.
Off board PCM Programming
2000 Silvermist GL2 Sedan w/ LX9 3500 V6
Current performance mods: TCE 65mm throttle body, ported 3400 upper intake manifold, ported 3500 lower intake manifold and heads, WOT-Tech Strip performance cam 276/264 adv duration .536"/.520" lift , COMP Cams 26915 Valve Springs, 28# Trailblazer Injectors, TOG headers, LS1 MAF, MMS Walbro 255 LPH Fuel Pump, Custom PCM tune and 4th Gen Camaro front calipersTags: None
I made one of those but I used a 12v wall wart rather than a battery charger... That's just nuts.
battery charger seems like a bad idea..... a lot of the ones i've come across don't have a whole lot of filtering on their outputs.... if you had even a garden tractor battery in there to keep things stable, it would make me a lot less nervous.
I haven't come across one yet with any sort of filtering. Well, maybe a smart trickle charger.Originally posted by robertisaar View Postbattery charger seems like a bad idea..... a lot of the ones i've come across don't have a whole lot of filtering on their outputs.... if you had even a garden tractor battery in there to keep things stable, it would make me a lot less nervous.
You could always drop $30 for an audio capacitor at Wal-Mart to filter the output.
Sent from my HTC One_M8 using Tapatalk-60v6's 2nd Jon M.
those ~1 farad caps aren't a bad idea, they don't have the capacity of a battery, but unless your power fails during programming, that shouldn't be too much of an issue.
Coulda swore I posted that somewhere, but couldn't find it again in search.....
Originally posted by AleroB888Here is an adapter to read and reflash PCMs out of the vehicle. It can use 12V battery power or as shown the nifty 15A Radio Shack power supply. In scan mode, the temp sensors "default" to -38 degrees:
Orange wire= pin#20, purple wire= pin# 58, Black wires= ground. It's very handy for verifying ID of salvage units.1999 GLS MP90 supercharged / 2003 GL MP62 supercharged / 2004 GLS stock
I used a gamecube power adapter,also the power in for the bench harness has a connector and I made adapters so I can plug it into the gamecube adapter, a cigarette lighter or alligator clips for a battery.
Before I found the gamecube adaptor I just used a spare car battery and kept it on a 2a smartcharger.
I used to have a power supply but used it quite often and it went out on me,I replaced it with a homemade power supply and then transistioned to what I use now when it became unreliable.Last edited by DefEddie; 05-17-2014, 11:44 PM.
