megasquirt tunning
  • boostedrs
    • Mar 2006
    • 168
    megasquirt tunning
    heya is anyone here familair with megasquirt tunning??
    ive got a base tune setup,and id like to see if one of u guys could check over my settings for anything stupid i may have messed up.
    ive also got a ? about the iac,im gonna run piggy back at first so im gonna let the stock ecm control the iac still,but what do i set the settings in ms to?
    hopefully ill get the ms installed this weekend
  • boostedrs
    • Mar 2006
    • 168
    opps can somone move this to computer tuning for me i posted it to the wrong section
    • boostedrs
      • Mar 2006
      • 168
      doh it would prolly help if i posted the file lol
      had to change the file ext from .msq to .txt to upload it
      • sharkey
        • Jun 2004
        • 2061
        that txt file doesnt help me out much. if you can post your .msq file (or e-mail to me) i would be happy to look at it. also, what code are you running???
        set the idle control to "none"
        • boostedrs
          • Mar 2006
          • 168
          that is the msq file. i had to change the file ext to txt to post it here ill upload the file in a zip file instead
          ms1 v2.2 reg ms1 code
          • sharkey
            • Jun 2004
            • 2061
            your tune up looks decent. a couple things i noticed was your after start enrichment is too low, normally you run 25-45%, you have it set at 10. your injector settings look fine for high impedience injectors. i would put your decel fuel % up to 100% for tuning and play with it later. all it does is cut the fuel for the same length of time as your accel fuel, just when you let off the throttle. i find it makes the car quite jerky when quickly letting off the throttle. i dont even use it, its set at 100% on my car.
            • boostedrs
              • Mar 2006
              • 168
              thnx man,turns out om not even gonna be using that tune.ive changed direction with my car. starting tom im gutting the car and cutting out the whole rear floor section
              im seting up the motor with 11.0-1+ cr and running it on alcohol with ms
              its gonna be a track only car
              Power Adders - build diary : blown alcohol v6 - well the decision has been made, as of today my rs is no longer a street car. ive decided to do a real serious build,im still going to use my current engine/drivetrain setup,except im gonna turn the car into a purpose built drag car. as to give u an idea were im going...
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                awesome dude, keep us updated on the pictures, can never get enough
                sounds like an exciting project
