Megasquirt 1 - msn extra code tune files
  • project89
    • Sep 2008
    • 247
    Got a request for my tune files so i will post them all here
    this tune is using ms1 msn extra cde
    rwd iron heads, and boost, ve maps are setup for 18 inches of vacum at idle
    and 21 psi of boost
    spark tables ( good t 21 psi on 93 pumpgas/ abve 14 psi meth injection is highly advised,
    i need to screen sht the ther ones and then put all the files in a zip file t uplad them ill do it in a bit
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
  • carbon
    Procrastinator
    • 388
    More?
    - Ben
