What are the different intake manifolds i can put in place of the 31 intake manifold, do i need to change the heads or can i just change the upper and lower manifolds?
3.1 intake manifold help
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mileTags: None
I think the 3100 is close isnt it??? mite be wrong.. i know the 3400 is pretty far off juss by pictures and the way the ones look at the junkyardVIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
