Need smaller temp sensor
  • sd_iconoclast
    • 126
    I am attempting to use the serpentine setup from a 3100 on my fiero 2.8.
    However, I have noticed that the temperature sensor that screws into the front of the 2.8 intake manifold interferes with the 3100 timing cover. I would like to relocate this sensor to the top of the intake manifold next to the fan switch that also screws into the intake manifold. It would be helpful if I could find a smaller version of the temp sensor as space is limited.
    The fiero temp sensor takes two wires and appears to have a 3/8 pipe thread.
    Does anyone know of a smaller version of this sensor? Maybe one with a 1/4 or 1/8 pipe thread?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Get the 3 wire sensor off the Grand Prix. One sensor will run the ECM and guage. Move the fan switch to one of the heads.
    • sd_iconoclast
      • 126
      This sounds like exactly what I need.
      What year GP?
      It sounds like you are saying that the calibration of the sensor is the same as on the Fiero. Am I correct?
      • sd_iconoclast
        • 126
        I went out and bought one of these three wire sensors.
        Now does anyone know what pin does what?
        • RacerX11
          • 1060
          Pin A = Black, PCM sensor ground
          Pin B = Yellow, coolant signal to PCM
          Pin C = Dark Green, to Gauge
          '99 Z-28 - Weekend Driver
          '84 X-11 - Time and Money Pit
          Quote of the week:
          Originally posted by Aaron
          • geoffinbc
            • 5831
            Correct. And if it did not come with a pigtail then a TPS sensor pigtail fits.
