Swap 89s10 for 85 jeep cherokee
  • oldwillys
    • Mar 2007
    • 1
    I have a 85 cherokee with a bad engine any problems using a engine for a 89 s10 both or 2.8 . I see know reason why it would not work but have learned its best to ask first.
    thanks Ed
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    An 85 engine would be an external balance engine while the 89 engine is an internal balance engine. You will need to use a neutral balance flywheel/flexplate for the 89 engine. That is pretty much the only issue. Transfer over all your 85 parts to the 89 block and you will be ready to go.
