2.8 to 3.1
  • steelbender
    • Jul 2007
    • 8
    2.8 to 3.1
    I have a 86 s 10 4x4 pickup 5 spd manual with a dead 2.8
    I have been given a freshly rebuilt 3.1 out of a chevy lumina (a 91 I think)
    what would be involved in swapping out the 2.8 for the 3.1
    I plan on ditching the multi port off the 3.1 and using the tbi off the 2.8
    and If I am reading things here on the site right I will have to switch the front covers for the original v belt and serpentine pulley system to work right
    due to the reversed water pump setup.
    What else will I need to do?
    Steelbender
    Live life 3.7mi at a time
    • 4555
    It's not an easy swap. The FWD block doesn't have the same mounts, and the starter is on the wrong side, along with a few other things.
    • steelbender
      • Jul 2007
      • 8
      fix up the 2.8
      Sounds like I should fix up the 2.8 instead
      thanks for the input.
      Steelbender
        Steelbender
        you could swap the guts over into your 2.8 block and have a 3.1...
        i'd also keep the MPFI setup as it's much better than the old iron head stuff.
          • 4555
          I don't think so. If I'm correct, he has the small journal block and the FWD pistons would give low compression in combination with the iron heads. I started to say the same thing at first, but ended up editing the post .
            that's why i suggested the aluminium head stuff.. keep the compression at 8.8:1.. lol
            but either way..
            best bang for your buck if you want to keep it iron head, grab a 3.4 from a 95 ish Camaro and swap on your top end.
              • 4555
              He would have to fabricate some way to have DIS with the aluminum top end, the distributor won't clear the lower manifold. A 3.4 has these provisions.
