Front cover
  • CNCguy
    Bisong eater :P
    • 1017
    Front cover
    Are the timing chain/front covers interchangable between FWD & RWD engines? To be more specific, is there a RWD cover that will fit a 95' 3100? I am wanting to move my water pump and aternator to make room for billet valve covers and headers.
    Thanks,
    Marc
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Yes it will physicall bolt on but nothing, accessory wise, from a FWD motor will fit.
    • CNCguy
      Bisong eater :P
      • 1017
      Thats what I thought and was hoping to confirm... Thanks
      Marc
      '79 MGB - LZ9 - T5
      • geoffinbc
        • 5831
        Remember that its gotta be a serpentine front cover since the belt turns the pulley from the back side so it is reverse direction. Also a 1993 to 1995 cover from a Camaro will have the mounting holes for the 7X crank position sensor if you are using an SFI system. There are also differences between the Camaro and the S-10 pumps. The S-10 has what you would call a long shaft pump while the Camaro is short.
