3900 V6 Info also 6spd manual
  • KnightZeroOne
    Racer
    • Aug 2007
    • 3
    Ok im looking at swapping to a bigger motor from a 3.1 trying to get some info on the 3900 V6 in the G6. Has anyone worked with these yet. I know its a relatively new motor, just trying to decide if i would be better going with a 3400 or 3500. Main main questions are Does the 3900 have an aluminum block. I plan to build this motor from the ground up and an aluminum block is desirable. Also I have a 5 speed manual now. What 6 speed fwd trans are available? I know the G6 has an available 6 speed, but i havent really seen it available before in a fwd gm car.
    The car to be modified is a 1994 Chevy Cavalier Z24 Convertable
    Current setup is a 3.1 MPFI and 5spd Trans, Right now the rough plan is going to a built 3900 60° V6 with turbo's and a 6 spd any input is appreciated
    3.1MPFI 5 Speed
    Undergoing Mods soon
    • 9191
    I'd say start here...
    http://www.60degreev6.com/showthread...highlight=3900
    And then here...
    http://www.60degreev6.com/showthread.php?t=37640
      the 3500 non VVT is an easier swap, there is even a front mount for the Jbody in the design stages for that specificially. With a few upgrades it'll out-perform that 3900.
      there are only 4 running 3500 swapped Jbodies known right now.. and 2-3 more in progress.
      • Nightingale
        • Apr 2005
        • 259
        The 3900 is still has the iron block I believe. Also no one that I know of has swapped a 3900 into anything yet. I have one coming but I plan to rewire the car for the g6 equipment since no one has a working solution for the vvt other then locking in the cam phaser at the desired timing, altough Joseph Upson is working on a standalone using a basic stamp I believe.
        98 camaro swapping in lz9 th400 setup
        LZ9 specs: (Subject to Change work in progress)
        4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
        • KnightZeroOne
          Racer
          • Aug 2007
          • 3
          Thanks much, gotta do some research i know they made an alum block for these
          3.1MPFI 5 Speed
            • 9191
            There is a GM Performance aluminum block that you can buy for ~$3k. But it won't really support any of the hardware from the 3900. There is also the new 3.6DOHC that is an aluminum block.
            • Joseph Upson
              It was also mentioned in the 3900 thread that resizing the pre 3900 cam journals to install non VVT cams is an option. CNCGuy took that route.
              • KnightZeroOne
                Racer
                • Aug 2007
                • 3
                Interesting, though i dont think the 3600 dohc will fit in the engine compartment
                3.1MPFI 5 Speed
