need help
  • rlue
    • Oct 2007
    • 9
    need help
    I HAVE A 1987 CAVALIER RS WITH A 2.8 i WANT TO SWAP A 1998 3.1 FROM A GRAND AM CAN ANYONE GIV ME DIRECTION ON HOW TO DO THIS?
    Live life 3.7mi at a time
    • 4555
    It's not an easy swap to put a FWD motor in the fbodies. The Camaro 3.4 is an easier swap.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Isn't the 87's TBI?? If so, you might need to swap the harnesses to the 88-93 OBD1 harness or just swap to OBD2 if you want dhp. You'll need to fab up an engine mount I'm pretty sure. Other than that & swapping a few parts and making a few adjustments/alterations it should be straight forward.
        • 9190
        It must be too earlier for you to be posting, cause nowhere in that thread do I see any mention of an F-Body. Last time I checked, an 87 Cavalier was a J-Body.
        Check out www.domesticcrew.com for probably the best writeup on this swap.
        • rlue
          • Oct 2007
          • 9
          my cavalier is a fwd does this make it easier. Can I use my tranny its a 3speed auto?
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            You can search I mean use your tranny.
            • rlue
              • Oct 2007
              • 9
              Yes it is a multiport can i use my intake and harness or should I use everything out of the Grand Am?
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                If your car has 6 injectors and a maf/speed density setup then your harness is there for you and half your job is done already. Define, "can i use my intake"
                  • 4555
                  Maybe too early, or the caps lock, could have sworn it said Camaro RS
                  • rlue
                    • Oct 2007
                    • 9
                    I have the whole 1998 Grand Am so I can use the wiring out of that if it will work. Will the Tranny from the Grand Am fit in the Cavalier it may be a fourspeed auto?
                    • rlue
                      • Oct 2007
                      • 9
                      It has six injectors one for each cylinder. I want to know if I can pull the top end off my 2.8 and bolt on to the 3.1. It is a 2 part intake. the top has what I call the throttle body the bottom has the injectors in it.
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        You will have to do more work than it is worth to make all that work.
                        Ok you need to do more research. You seem like you have NO idea what you are doing (dont take it the wrong way) . You'd hate to take apart a running or easy fixable car then in the end have to junk it and the donor car because it is way above your head.
                        • rlue
                          • Oct 2007
                          • 9
                          you are right I am learning al about this, thabeing said the 2.8 has a cracked block so I have to do something. So you are saying that I should use my old tranny it works fine by the way, and use the fi from the 2.8 to make it easier.
