1988 corsica 2.8 -1993 corsica 3.1 engine swap
  • thrust
    • Oct 2007
    • 4
    i have a 1988 corsica with a 2.8(3spd a/t tranny), there is a pretty heavy knocking sound from under the front head, i took off the rocker arm cover, there is almost no oil pressure out the push rods. i think the oil pump went and possibly caused a rod bearing or lifter to go(causing the knocking).
    i have a friend with a 3.1 with only 130K on it, he flipped it and caved the roof in. i'm thinking of putting his motor and tranny(4spd a/t) in. the pcms are both the same, with different proms, can i just swap the motor and tranny, hook up the bulkhead wiring harness connector, change prom and be back off to the races.
    any insight would be appreciated
    • 9191
    The Corsica didn't get a 4-spd auto until 1994. The 93 should have the same tranny as your 88.
    As far as the swap goes, yeah it should be just about that straight forward.
    • thrust
      • Oct 2007
      • 4
      2.8 to 3.1
      will a 3.1l lumina block with a vin code d fit in my 1988 corsica if i used all of my 1988 emission control devices and a custom chip set for batch ignition on 3.1 displacement? the 3.1 out of the corsica didn't pan out.
      • 3100 MPFI
        • 1522
        3.1 in a Lumina should be a vin code of T.
        The Lumina only had 3 engines that I am aware of. The 2.5 which is an R, 3.1 which is a T, and 3.4 which is an X. The newer Lumina's also got the buick engine 3800 which is a K, and the 3100 which is an M.
        Even still, the block's are all the same between the V6's (3.1).
        You can even use the vin M block (3100), but if you did that, you would probably want to go ahead and use the complete 3100.
        I also looked at the older VIN CODES for the GEN 1 engines. The camaro 3.1 was still listed as a vin T, and the newer camaro 3.4 was an S.
        Kinda need to know more about which engine you are going with. Unless you just happened to find something I have not ever come across.
        Even still, you can get ANY 3.1 block (1989-1993 and the 1994 3.1 Lumina) and pretty much drop it right in. It will bolt right up to everything you have in there.
        Taylor
        1998 Lincoln Mark VIII
        • johnnymossville
          • Jul 2007
          • 255
          His 3 spd. auto may be a T125 without a lockup torque converter as this was the standard auto trans in the earlier cars. The '93 3.1 Corsica came with a T125C which has the lockup torque converter and many people mistake it as a 4 sp. trans. Brad was correct in saying the 4 spd. auto was not available in the Corsica/Beretta cars until '94.
          • thrust
            • Oct 2007
            • 4
            2.8 to 3.1 crankshaft
            if i throw a stock 3.1 crankshaft into my 2.8, will it turn it into a 3.1? are the connecting rods and pistons the same? i can get all of these things in ebay for cheap.
            • 3100 MPFI
              • 1522
              you need to swap out the connecting rods too.
              A 3.1 is nothing but a STROKED 2.8. Put in a 3.1 crank and connecting rods and you have a 3.1
              Taylor
              • thrust
                • Oct 2007
                • 4
                high lift camshaft
                i'm going to put a high lift camshaft into my engine with a 3.1 crankshaft, do you guys know if i need a custom programmed chip? also i checked the casting numbers in the 2.8 and 3.1 connecting rods, they are the same. so all i need to do is replace 1 because i spun a bearing and it screwed the rod, and my crank got worn down some as well, thats why i'm going to move up to a 3.1 crank.
