hybrid question, yes i searched
  • Mr_Efficiency
    • Jan 2008
    • 197
    I know if i use a 3.1 bottom end with a 2000ish 3400 top end I need custom length pushrods cause the 3400 uses the fancy fulcrum (i think thats what they were called) rockers. but I also found out that if you use a 94-95 3100 top end you dont need custom length pushrods cause they use the same style rockers as the 3.1.
    So does that mean I can run a 3.1 bottom end with a 2000+ 3400 top end with 94-95 rockers and i could use the stock length pushrods?
    thanks
    Mr_Efficiency
    90 Grand prix - Lawn ornament
    Black, 3.1, 5 speed
    Future holds: Striped and then scrap yard
    97 Cavalier - Stock car
    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
    Future holds: Just more trophies
    New project on the way: 88 S10 reg cab, short box, 5 speed.
    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
  • TazMan
    • Jun 2006
    • 285
    No you still need custom pushrods. They hadn't change to roller rockers yet. They were stamped steel rockers but they have the same 1.6 ratio as the roller rockers.
    • Mr_Efficiency
      • Jan 2008
      • 197
      I knew they were 1.6 ratio, I've heard of guys that have gotten away without custom length push rods cause they used the 94-95 top end. guys on TGP forums have put the 94-95 3100 1.6 rockers on with stock length pushrods no problems.
      Mr_Efficiency
      Black, 3.1, 5 speed
      • TazMan
        • Jun 2006
        • 285
        I asked this question a long time ago and I was told no by several people. I don't remember the reason it worked for some people. Something about a certain set of rockers that fit on this heads cause they were stamped steel, but worked with the old pushrods. I know I was told I would absolutely need custom length pushrods.
        • 3100 MPFI
          • 1522
          it is not so much the ROCKERS that is different, but the LIFTERS.
          The 3.1 uses FLAT TAPPET lifters which sit FLUSH to the block mounting areas. The 3100 uses ROLLER lifters which protrude, and are held in with ANTI-ROTATION bars. So the 3.1 I think will have LONGER pushrods, and the 3100 will be SHORTER.
          Just because they did it and it workes does not mean they are seeing the full gains.
          When I had the camshaft in my 3100 REGROUND to custom specs, I just reused the stock pushrods. When I finally got around to replacing the stock pushrods with some CUSTOM ONES (that made up for the difference in material that was removed for the regrind), I got a NOTICABLE gain.
          You would be better off taking some measurements, and then having some custom pushrods made.
          Taylor
          1998 Lincoln Mark VIII
          • Mr_Efficiency
            • Jan 2008
            • 197
            and i probly shouldnt even bother asking but i guess you cant just swap out the lifters can you?
            Mr_Efficiency
            Black, 3.1, 5 speed
            • TazMan
              • Jun 2006
              • 285
              Well I think that was what they were doing. IIRC, there are a set of stamped steel rockers that bolt to the 94-95 heads and work with the old pushrods. If I'm right, I'm sure someone here has used them and will chime in soon.
                • 9191
                You can't run hydraulic roller lifters on a flat tappet cam.
                • 3100 MPFI
                  • 1522
                  One thing you could do is use a 3.1 MPFI cam (it will fit), and normal FLAT TAPPET lifters. You can then use the 1994-1995 heads with the stamped steel rockers, and the 3.1 MPFI pushrods.
                  That might work for you.
                  If you change the lifters (from one style to the other), then you have to do the cam as well.
                  Taylor
                  • Mr_Efficiency
                    • Jan 2008
                    • 197
                    I'm using the 3.1 bottom end, so I dont need to change the cam, I'm just wondering if i can use the 3.1 lifters in the 3100 heads.
                    Mr_Efficiency
                    Black, 3.1, 5 speed
                      • 9191
                      The lifters are in the block, not in the heads.
                        treeZ24 is running stock 3.1 pushrods with 3400 heads. He has aftermarket rockers but not sure if that makes a difference they are still 1.6:1. It may vary depending on your cam setup but he said on his it was close enough so he ran them. His car is fast too.
                        His cam specs:
                        duration = 210* at .050" (256* advertised) with .295"cam lift @ 112* c/l
                        Of course you are going turbo so a re-ground cam for boost would have to be considered if you are wanting a cam.
                        • TazMan
                          • Jun 2006
                          • 285
                          I feel so dumb for even asking this but a google search didn't really help me much. I don't know why but I thought "lifters" was just another word for rockers. Sorry for still being such a noob. I'm still trying to get all the terminology down. So what are the lifters.
                            • 9191
                            The lifters are the parts that ride on the camshaft:
                            For valvetrain order, it goes CAM, LIFTERS, PUSHRODS, ROCKER ARMS. The ROCKER ARMS are mounted on the VAVLESPRINGS, and actuate the VALVES.
                            • Mr_Efficiency
                              • Jan 2008
                              • 197
                              3100mpfi said the lifters was the reason the pushrods wouldnt work, but if i use a complete 3.1 valve train, cam, lifters, pushrods, rockers, with 3100 heads I should be ok right? I'm pretty sure thats what was said above but i just want to clear it up and be sure.
                              Mr_Efficiency
                              Black, 3.1, 5 speed
