2.8?
  • Mr_Efficiency
    • Jan 2008
    • 197
    2.8?
    I am planing on building a hybrid motor and boosting it, but i want minimal down time on my car and instead of rebuilding the motor in the car I was looking at getting another motor and building it then taking the car off the road for a weekend to swap in the new motor.
    I was planing on using a 3.1 but i came acrossed a complete 2.8 for free.
    What would be the downsides to using a 2.8? its the exact same as a 3.1 isnt it, except for the stroke obviously. I would get better gas mileage, lol
    there is only a five hp and 5tq diffrence in the two motors, so its not a huge deal to me, im not looking for all out race motor, just something boosted to have fun with.
    is the 2.8 and 3.1 cam the same?
    anyone ever hybrid or boost a 2.8?
    atleast i'd be diffrent
    Mr_Efficiency
    90 Grand prix - Lawn ornament
    Black, 3.1, 5 speed
    Future holds: Striped and then scrap yard
    97 Cavalier - Stock car
    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
    Future holds: Just more trophies
    New project on the way: 88 S10 reg cab, short box, 5 speed.
    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
  • 3100 MPFI
    • 1522
    The 2.8 hybrid will be the same as the 3.1 hybrid.
    In fact, I threatened Ben that if he kept pissing me off about using a 3100 instead of a 3400, or 3500, I would stick a 2.8 crank and rods in there and have a 2800.
    All the 2.8 is is a destroked 3.1 MPFI. I think that the 2.8 revs up faster and higher (due to the shorter stroke). I know my 3100 revs higher than a 3400, but that is a built-up engine.
    Taylor
    1998 Lincoln Mark VIII
    • Mr_Efficiency
      • Jan 2008
      • 197
      I've been reading up on this more and i have a few more questions:
      what will my compression come out like? are the 3.1 and 2.8 heads the same? if yes then the compression will be ok.
      and what about injectors, I need less fuel now that i have less displacement, so I might be ok with stock TGP 22lbs injectors then with 9psi, correct?
      Mr_Efficiency
      Black, 3.1, 5 speed
      • 3100 MPFI
        • 1522
        can't help with the turbo, but to the best of my knowledge, the ONLY changes were the stroke.
        The heads ARE the same (I have 2.8 heads on my 3.1 right now). As for the fuel injectors, I am pretty sure those were the same as well.
        Taylor
          • 9191
          What year 2.8?
          • 3100 MPFI
            • 1522
            My 2.8 heads are 1988 and 1989 (from 2 different cars).
            I am not sure about all the years, but I know for a fact the 2.8 was used 1987-1989 in the gen 2 form.
            Taylor
              • 9191
              The question I have is for the original poster. If the free engine he is getting is a pre-85 (??), then it has the smaller journal crank which is crap.
                Live life 3.7mi at a time
                • 4555
                Don't you mean use 2.8 pistons and crank in a 3100? The rods are the same, the pin height is different on the pistons.
                Yes hybrids and boosted gen1's have been done.
                Since you are doing a rebuild anyways, you can use 3.1 pistons and crank and it will be a 3.1. You need some 3100 (or Gen2 3.1) pistons with those heads if boosting. OR you can use the 3.1 pistons and have a high compression torque monster.
                *But* as Brad said, make sure it's an '86 or later or you may be wasting your time.
                • Mr_Efficiency
                  • Jan 2008
                  • 197
                  yeah its an 88 2.8, so its the good one. I'm thinking of leaving it a 2.8, and since the 3.1 and 2.8 heads are the same that means if i use the 3100 heads, I'll get the same compression ratio as if i was using a 3.1, correct?
                  what does the compresion of a hybrid come out to anyways?
                  Mr_Efficiency
                  Black, 3.1, 5 speed
                    • 9191
                    To test for CRs for various combos, use the site calculator:
                    To get values for the different engines, just do a stock engine calc and copy the numbers down.
                    • Mr_Efficiency
                      • Jan 2008
                      • 197
                      thanks a lot, i have some good calculators for that but just didnt have the specs, I'll give that a try now.
                      ... it says the 3100 and aluminum head 2.8 and 3.1 have the same combustion chamber cc's so my compression wont change.
                      Mr_Efficiency
                      Black, 3.1, 5 speed
                      • 3100 MPFI
                        • 1522
                        I think the only thing that might change with the compression will have to do with which headgasket you use. I think if you use the 3100 head gasket, you will lose some compression, but the 2.8/3.1 headgasket will keep it the same.
                        Something like that.
                        Once again, I am trying to think on an empty stomach. No food = no brain.
                        Taylor
                        • Mr_Efficiency
                          • Jan 2008
                          • 197
                          yeah i was going to ask about that, so the 3100 head gaskets are thicker?
                          Mr_Efficiency
                          Black, 3.1, 5 speed
                            • 4555
                            Gen3 pistons protrude .020" out of the block, hence the reason for .060" compressed height gaskets (gives you exactly .040" quench).
                            The RWD gaskets are .040" compressed height, and you may have valve slapping the pistons with high RPM's with only .020" clearance.
                            • Mr_Efficiency
                              • Jan 2008
                              • 197
                              ok thanks
                              what about the cam? i know i dont have the $$ for a new one but i was doing some research and found that the fiero 2.8 HO (L44) uses the same cam from the 3.4 in the firebirds and camaros. how much better is this cam over the stock 2.8/3.1 cam?
                              Mr_Efficiency
                              Black, 3.1, 5 speed
