cams
  • Mr_Efficiency
    • Jan 2008
    • 197
    cams
    I admit i dont know a hole lot about cams, I know there purpose and how they work and what most of the specs mean but when it comes down to how those specs affect a motor, i'm lost.
    I'm building a 2.8 with a 3400 top end with minor port work, just gasket matching and I'm running turbo all this bolted to a getrag 282.
    What kind of specs am I looking for? From what i understand turbo's dont like a lot of over lap, over lap is ok just not excessive like a lot of the bigger cams.
    I'm not looking for anything extreme, just a nice improvement over stock. this is mostly a daily driver but I do a lot of autoX and hit the drag strip a few times a year.
    also if anyone had any links to sites selling cams that would help out to.
    I've heard alot of good things about the H260, but hows it for boost?
    thanks
    Mr_Efficiency
    90 Grand prix - Lawn ornament
    Black, 3.1, 5 speed
    Future holds: Striped and then scrap yard
    97 Cavalier - Stock car
    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
    Future holds: Just more trophies
    New project on the way: 88 S10 reg cab, short box, 5 speed.
    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
    the crane H260-2 is a great cam for boost, lots of people are running it with good results.
    Since you are using a Gen2 bottom end your cam choices are somewhat limited, you could always get a regrind of a new stock one, you'll probably end up needing longer pushrods depending on the lift you want.
    Here is a great guide for gen2 cams: http://members.shaw.ca/betterthanyou...haft_guide.htm
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Limited? There are a lot more cams for the Gen I and II motors than there are for gen III. You can get Comp or Crane to make you a custom one if you wish.
        Um.. have you checked the store here lately?
        http://60degreev6.com/store/images/Cam/CamSpecs.htm
        Sure they're re-grinds but the end result is the same...
        • Mr_Efficiency
          • Jan 2008
          • 197
          awesome, thanks for the link superdave, thats just the kind of thing i was looking for.
          Mr_Efficiency
          Black, 3.1, 5 speed
          • Mr_Efficiency
            • Jan 2008
            • 197
            Just out of curiosity, can i use a gen 3 roller cam in my 2.8 block if i used the correct lifters as well? then would this allow me to run the 1.6 roller rockers with stock length pushrods?
            cause if not i was going to run 1.6 lifters from a 95-96 3100 cause there not roller and I can use my stock length 2.8 pushrods.
            I know there not the best but its the cheapest and for the 1-2hp it gains me i dont feel like the headache of custom pushrods.
            Mr_Efficiency
            Black, 3.1, 5 speed
              • 9191
              Not without some decent modifications... Since the cam is a roller cam, it requires roller lifters. And the roller lifters require an anti-rotation bar, which the 2.8 block doesn't have provisions for.
              • Mr_Efficiency
                • Jan 2008
                • 197
                ok i dont know what that is but it sounds like more work than i want to get into for this build. I'm used to OHC motors so all this pushrod stuff just throws me through a loop.
                flat tappet cam it is then.
                If i get an aftermarket cam like the H260-2 that everyone seems to recomend, can i still use my stock length pushrods? I'll be useing 95-95 non roller 1.6 rockers like i said above.
                Mr_Efficiency
                Black, 3.1, 5 speed
                  Has anyone ever looked into what it would take to modify the gen1/2 block to accept the anti-rotation bars or gen3 guides?
                  The gen3 ones are just plastic, it seems like it would be easy enough to either weld in some little mounts or maybe if there is enough area drill/tap the block and run a longer bolt with a litlte collar that the guide can slide over...
                  Maybe this spring i'll look around for a gen2 block to check this out on, seems like it could help out alot of people...
                  • geoffinbc
                    • 5831
                    I think you can use rods from a 2.8L or 3.1L FWD Gen II motor. Should be close enough if your using adjustable rockers.
