3.4 swap into 1985 Jeep Cherokee questions?
  • cardana24
    • 434
    #226
    Okay, a little bit of progress. I re did my grounds so now they are run to the factory location by the water inlet. I am now able to run a wire from the ignition to the pink wire going into the two pin connection being pluged into the top of the icm. the wire no longer gets hot or smokes.
    Now when I turn the engine over it actually fires, but will not fully catch...it burbles for about a second then turns off. So I am still having problems. With the cam postion sensor I am still not getting 12Vs when the ignition is switched on to the pin that should be getting 12V I am guessing this may have something to do with my problem? With my set up is the ECM supposed to be feeding the cam sensor power or is that something that I need to be running from the ignition?
    Also when I push the gas pedal it does not race the engine or anything, it still cranks/sputters out the same way it does if I am not pressing the gas at all. Any suggestions? I'm going to go look over wiring diagrams more.
    • ssterlingb
      • Mar 2008
      • 28
      #227
      On my diagram it shows that the ICM & cam position senseor is fed by a fused 12v feed from the ignition switch
      • ssterlingb
        • Mar 2008
        • 28
        #228
        It shows a 10 amp fuse feeding the pink wire to the cam position sensor and the ICM. It is on page 3 of what I sent you earlier.
        • cardana24
          • 434
          #229
          Yeah I see that in the wiring diagram. I am confused why I would be getting power at the ICM and not at the cam or crank sensors, because it looks like they all tap into the same line.
          • Canyonero
            Plays with Volvos now.
            • Sep 2006
            • 1112
            #230
            Have continuity from those connectors back to fuse?
            Sure you have the VATS bypass on there right? Seems like if it were firing at all, your crank sensor would be working, right? I think it can run without the cam sensor, it will just run the injection as MPFI instead of SFI. Actually, you changed the cam didn't you? Might not be able to use the cam position at all. What did you put in?
            • cardana24
              • 434
              #231
              Which connectors are you talking about?
              As for the VATS bypass I assume I have it hooked up right. When I turn the ignition on the led lights up. I don't have my wiring diagrams with me right now so I cannot give you pin numbers. I have the power wire for the vats bypass hooked to the ignition wire on the ecm. I have the VATS bypass wire going to the dark blue wire, and then the ground is soldered into one of the ecm grounds. Should I try grounding the bypass somewhere else rather than tieing into the ecm ground?
              • cardana24
                • 434
                #232
                still the same thing. Crank then sputters out. I still cannot push the gas pedal to make the engine race either. I have tried both computers again. I now have power at the crank sensor pink wire, the ICM pink wire, and the cam position sensor pink wire. Also the pink/black wires that come off of the cam and crank sensors are going back to the correct pin on the ecm...the #6 injector feed line. That's about it. I could use some help here.
                • ssterlingb
                  • Mar 2008
                  • 28
                  #233
                  Do you have the MIL (malfunction indicator lamp, or service engine soon light) hooked up yet? If so, it should be on when you turn on the key on and stay on untill it starts. If the light does not go on, it indicates that the VAT is the problem.
                    • 9189
                    #234
                    IIRC, he doesn't have that light hooked up. But it would definately be a good idea to hook it up to some light source, as it could also tell you what sensor is your problem (if it is a sensor).
                    10 Pin Blue Harness
                    *Lt Blue- C10 2nd start mode switch signal (not hooked to anything but when the ignition is switched on it gets 12V)
                    *Brown/White- B7 SES indicator control Nothing
                    *White- Nothing (Caynonaro said its for the tachometer) Nothing yet, I'm waiting for my MSD adaptor thing
                    *Dk Blue- Nothing Nothing
                    *Green/White- A2 A/C request Nothing
                    *Pink- C3 Ignition Feed Hooked to the ignition line from the jeep
                    *Lt Blue/Black- A18 Brake signal Nothing
                    • cardana24
                      • 434
                      #235
                      I have some extra LED's laying around, I could hook one of those up so I can see the check engine light, but then how would I check the code? I don't have an ALDL (I forget the initials but the diagnostic port) hook up and I don't have the reader. I was reading that you can just ground to pins on the port and you can get the codes, but I don't even have that port. How can I go about finding the codes if I only have a CEL but not port to read it?
                      • ssterlingb
                        • Mar 2008
                        • 28
                        #236
                        I would use a 12v light instead of an LED. Since the ECM provides the ground, it might use the 12v+ feed through the bulb to complete some kind of diagnostic circuit. An LED is a diode, & won't let the current flow through when unlit.
                        • cardana24
                          • 434
                          #237
                          That's fine I can pick up one of those tomorrow. Which two wires would I run to it? I see the one that goes to it, but what is the other one?
                          • ssterlingb
                            • Mar 2008
                            • 28
                            #238
                            One side of the MIL goes to 12+ ignition & the other side to the ECM on B7 BRN/WHT
                              • 9189
                              #239
                              Hmm... as far as the codes go, you might be SOL. Cause now that you mention it, even if you had the port, I'm thinking the ECM is an OBD-1.5 setup, so you can do the old "paperclip" method anyway. So you may not be able to pull codes.
                              • cardana24
                                • 434
                                #240
                                I have not been able to work on the jeep any more over the last few days but I should be able to get back to it tonight. I went to the junk yard yesterday and found a 3.4 firebird. I ended up taking all of the wiring from the grey/black (the clip with the the two pink wires for the injectors that I have tied into the ignition line) clip all the way to the factor fuse box. At the fuse box I cut the wiring going into the cabin of the car because I assume I do not need that since all of my stuff on the inside of the car is already run off of my jeep fuse box. I also realized that the other clips that I have been trying to identify the wires too go inside of the cabin at on the passenger side...so I am assuming I really do not need to do anything with these.
                                Also I noticed that the firebird had three black/white wires, and two tan/white wires grounded by the water neck. Currently I only have two black/white's and two tan/white's grounded at that point. So that is something else I will have to look into.
                                I also cut the ALDL port out of the Firebird, so I have that port with ~6" of wiring connected to it. Can I do anything with this?
