High oil pressure
  • pbeck
    pbeck-68
    • Mar 2008
    • 32
    High oil pressure
    I have a 89 cavalier with a 3400 in it and I haven't had any problems other than the oil pressure gauge!!! I t is constantly reading 80 psi and greater. The oil pressure sending unit is new, and this is driving me nuts. Any help would be great.
    Thanks, Paul
    which sending unit did you use?
    you need to use one for the original 2.8, it should be the longer one.. the short stubby ones are just for dummy lights.
    • pbeck
      pbeck-68
      • Mar 2008
      • 32
      The one that was in my 2.8 was the wrong thread size. The one I am running is out of a 97 venture van.
      • merlot566jka
        • Nov 2006
        • 570
        thats the prob, use the one for your car.
        also check your fuel pump relay and fuel pump fuze, make sure there both working.
        2012 Chevy Sonic Turbo 6spd
          one (long one for gauge) from a beretta will fit, but not sure if it will work with you ECM. I'm guessing it should. I bet the Lumina one is a short dummy light sender.
          • pbeck
            pbeck-68
            • Mar 2008
            • 32
            What year beretta do I need it from?
            • Barry
              95 Beretta LG8 Action
              • Aug 2007
              • 269
              Yeah, thats your problem. I put a full cluster in my beretta, and my oil pressure guage is pegged...
              95 Beretta- Lg8 Daily Driver
