planning stage; 3500 into fiero
  • cooguyfish
    • Jul 2008
    • 31
    I don't feel like typing out a lot of info so let's just start with the basics
    -I'm looking at an 05 3500 out of a G6 and want to make sure this is a good engine
    -Planning on running the GM 7730 ECM and a manual tranny to keep things simple. I've heard that at one point, someone had the info off of the turbo grand prix's ECM's and I would like to know if this can be put onto a 7730 ECM (for now, I will go N/A, get the engine in, play with it, have fun and then build a turbo kit for it).
    -I've heard that I need a 3400 fuel rail, which year should I get and where should I get it from?
    -planning on dropping the ETC and getting a regular throttle cable throttle body, what and where from?
    -That's all I've got off the top of my head, anything you would like to tell me would be terrific.
    -Brandon
  • Guest
    tgp prom would easily be adaptable to the 7730 for the 3500
    • merlot566jka
      • Nov 2006
      • 570
      hi. i built the only 3500 fiero.
      check on .nl i answered ur questions
      2012 Chevy Sonic Turbo 6spd
      • nfswift
        • Aug 2007
        • 58
        I'm slugglishly chasing at your coat-tails!
        Damn my fascination with motorcycles distracting me from my Pontiac!
