92/95 swap
  • jlduster
    • Apr 2004
    • 14
    92/95 swap
    Just purchased 95 3.4 dohc to install into 92 Z34. The intakes are different (sfi vs. mfi). What, if anything can I do to make this swap? I have the exhaust manifolds from the 95. The intake looks like it will physically bolt on. I have commited to it now, if it won't work, will have to buy another motor. Any help will be greatly appreciated. Thanks.
  • jmgtp
    • 1219
    The intake manifolds are the same. Identical. The difference between MPFI and the SFI engines is entirely in the computer and wire harness. As far as I know (and I really dont since I've never done such a swap, I really just wanted to point out that the hardware on the 2 engines is identical) the 95 should be an easy swap as all the sensors the 92 uses are in the same spots and the same ones. The 95 may have a few extra sensors that you would just ignore, such as the cam position sensor and I believe they had more than 1 crank position sensor when it went to SFI.
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
    • jlduster
      • Apr 2004
      • 14
      alt.
      FOUND PLUG AND INSTALLED. THANKS.
