Getting ready to install the 2.8L motor in my dune buggy. Was wondering if anyone had shortened up the oil pan so it doesn't hang down so far. Its not totally unreasonable, but would like to make it a bit shorter if possible. Also, its out of an 86 S10 blazer. Any help is greatly appreciated. Thanks.
2.8L Oil pan
if you shorten it up make sure you add the removed volume somewhere else. it only holds 4.5 qts as it is, not a good idea to go any less.Originally posted by eggman View PostGetting ready to install the 2.8L motor in my dune buggy. Was wondering if anyone had shortened up the oil pan so it doesn't hang down so far. Its not totally unreasonable, but would like to make it a bit shorter if possible. Also, its out of an 86 S10 blazer. Any help is greatly appreciated. Thanks.
0.02'86 Grand National
Was the Blazer 4X4? The Camaro pans and 2WD S-10 pans are a lot shorter. If you can use that pan then it is easy to get the correct pickup for the pump too.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
