3.1L into 2m4 fiero..let me have it
  • dCaHnAnOyS
    600cc shifter cart
    • Feb 2009
    • 4
    I just picked up a 1984 Fiero 2m4 4speed -m.
    I found a 3.1L with 30,000 in it
    comes with the harness & ecu
    Now I understand that there are 3.4 4.3 350 383 3.8 and 3.8sc swaps that can be done.
    But I have a set amount of cash and the 3.1 would make me happy enough.
    My question is..does the 3.1-2.8 block mount right up to the stock 4 speed manual trans I have in the car?
    And any other info on this swap would be a huge help.
    thanks
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Yes the trans bolt pattern is identical. You can use everything from the 2.8L on the 3.1L
    • TiredGXP
      • Jun 2008
      • 107
      You'll have to modify the cradle to put a v6 in place of the iron duke because of different engine mount arrangements. Lots of threads on PFF discuss the swap.
      http://www.fiero.nl/cgi-bin/fiero/Ul...i?action=intro
      • dCaHnAnOyS
        600cc shifter cart
        • Feb 2009
        • 4
        I was told that the motor mounts are the same due to the fact that the 2.8 was an option. no?
        and as for that other forum ..Its great but I couldnt find a 3.1 swap on there.
        So any help you guys can give me is awesome.
        So other than motor harness and ecu what will I need?
        • TiredGXP
          • Jun 2008
          • 107
          Here's a thread on swapping in a 2.8 for a 2.5. A 3.1 isn't too different from a 2.8 swap unless you want to switch over to a DIS ignition...
          http://www.fiero.nl/forum/Forum2/HTML/096895.html
          V6 wiring harness is different from the 2.5. Did you get the wiring harness and engine computer with the 3.1?
          Edit - duh reread your first post, you have the harness and ECM
          • dCaHnAnOyS
            600cc shifter cart
            • Feb 2009
            • 4
            So this shouldnt be that hard at all.
            now will the front harness of the 2.5 plug into a 3.1L ecm?
            Oh and tiredGXP great link thank you.
            Also what about the fuel pump?
            • LeftVentricle
              Right aorta
              • Oct 2005
              • 501
              Iron Duke fuel pump runs at a way lower pressure. You'll need at least a 2.8 MFI pump.
              • dCaHnAnOyS
                600cc shifter cart
                • Feb 2009
                • 4
                OK..that i can take care of.
                now is there anything elce I should know? I just want to make sure I have everything when I get started.
                • mongo
                  • Feb 2009
                  • 158
                  You can probably save yourself a lot of headaches by grabbing a 2.8 cradle. Don't forget the exhaust on a Fiero can be a nightmare to fabricate.
