GMPP HT 3.4 swap into s10
  • 60degrees10
    • Mar 2009
    • 4
    Ok heres my s10 which use to be a tired ole 2.8, but now the new HT 3.4 powerplant takes its place.
    Mod's include:
    Edelbrock 4 brl intake
    holley 600cfm 4brl carb
    accel hei coil
    accel 8mm wires
    hedman street headers
    and a lil bit of chrome to make it stand out
    Future mod's include:
    comp 260H cam
    1.6 rockers
    msd cap and rotor,coil,wires, and 6AL ignition box
    vette radiator
    16 inch electric fan
    8.5 disk brake rear with 3.73 gears and a zexel posi
    how fast are you spinning that 3.4? that 600cfm carb sounds like way too much......
    that should get you pointed in the right direction
    • 60degrees10
      • Mar 2009
      • 4
      yea a 390 cfm 4brl is what i was told would work, but i've been using the 600cfm holley for a little over 7k miles now and it runs great. plus i just happend to pull that carb off another one of my project vehicles and i used it.
        the HT 3.4 allready has the Crane H260-2 camshaft installed, the Comp 260 would be a sideways step.. If you want more top end power with a healthy idle the Crane H272-2 cam might do the trick.
        Nice swap though!
          if you want to spend the time to get it running great, then a 1200cfm double pumper might work eventually but it would take a while to get there..... that and with a carb that big the off idle to WOT bog would be about as bad as a turbo meant for a big block stuck on a metro.....
          but if it works, it works....
          • ezrollin
            • 205
            The HT 3.4 cam is a good daily driver with a good power boost,next step up would be the 272 but you might want to talk to someone who's running one before making any changes. I ran a 390 on mine,can't imagine a 600 on anything but an all out engine,your secondaries may not even be opening.
            • 60degrees10
              • Mar 2009
              • 4
              thanks i'll look into that, like i said im learning as i go. This 6 is new to me im use to hot rods and drag racing, but i just want this to be my daily. Might run it down the local strip on the weekends.
