Swap for cavalier z24 mod 94
  • Rocko
    • May 2009
    • 4
    Hi everyboy... i wanna know what of this motors is the best option for my cavalier z24 mod 94 3.1 L considering cheap and less dificult to adapter to my car..
    i wanna the motor 3500 but i dont know what is the best option considering the before i mentioned because existing 3 models LX9 LZE and LZ4
    What is the best option and what i need to do the swap, exist some guide???
    I hope someone could be help me
    Thank you...
    Sorry by my english... im still learning jejejeje
    all you ever wanted to know about engine swapping and Cavaliers can be found here: http://www.v6z24.com/jbodyforum/j-bo...rmance-f2.html
    I did the LX9 3500. It required heavy mods to the rear motor mount, completely custom front mount, external crankshaft trigger and lots of other random things covered in the 3500 swap sticky here: http://www.v6z24.com/jbodyforum/3500...ls-t98567.html
    • Rocko
      • May 2009
      • 4
      thanks for the info... i register in the other forum too..
      How much you took for adpater the motor in your car???
      • RedBird
        Aka Mr. 5th Motor
        • Sep 2006
        • 426
        a stock 3500 will run you around 2000ish is my guess. with added go-fast stuff, another 1000. i'll be close to 2000 on my 3500 build, but that's only because i already had a 3400 swapped in before i started.
        Cammed 3400 --> 224whp 210wtq
        Cammed 3500 --> ???
        1 of 5 3500 J-Bodies
        • Rocko
          • May 2009
          • 4
          Sorry i dont understand you answer... 2000ish what is the mean??? i refer to time for make the adapt.. and well the money too jejejeje
          Sorry again
            2000 dollars for the 3500, redbird will have to tell you about the time necessary
              $2000 is a good estimate for the total cost to put in a 3500 and get it running.
              I modified the mounts and made my own front mount for free at work, there are build plans for a 3400 mount on www.v6z24.com.. it would need to be modified slightly to work with a 3500.
              If this is your first swap, then i'd go for a 3400. It's a little less involved and will still make great power. Here are the details: http://www.domesticcrew.com/installguide.htm
