would a 3.4 crate engine swap into a 94 lumina eurosport easily or am I stuck with this weak powerplant
3.4 in a 94
Tags: None
3.4 crate is a RWD iron head engine, so no it wouldn't work. Since I can't remember what Luminas got in 94, is it the 3.1L or the 3100?-Brad-
Well it depends on which 3.4 you're talking about... is it the 3.4 DOHC? The 3.4 HT offered by GM? The DOHC can be swapped in, unlike the 3.4 HT truck engine. Oh, and the stock Lumina engine should be a MPFI 3.1L.
Thought I'd mention that, since there's a 3.4 DOHC crate on ebay right now.60v6's original Jon M.
I think he is talking about the HT3.4L.
If you have a 3.1L or 3100 then put in a 3400. Its easy enough to do and gets great results.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
