fwd vs rwd
  • p3313r
    noob
    • Apr 2007
    • 2
    fwd vs rwd
    im new to the 60 degree ownership expirience and i want to put 3.4 top end on my 3100 i found a guy with a rwd 3.4 in a 95 camaro and wanted to put the top end on mine is there a difference? thanks for the help
    • 9190
    First, welcome.
    Second, you don't want, nor can you even, do that. The 3.4 Camaro intake is for iron heads and is therefore incompatible with the aluminum heads on your 3100. Second, the 3.4 intake flows WAY WORSE that the 3100 intake. So even if you could do it, it would be a downgrade in performance.
    • p3313r
      noob
      • Apr 2007
      • 2
      thanks i thought it was gonna be a deal but oh well ill keep looking for a top end
      btw this site rocks n-body.net takes months to get a response
      thanks again
      • no_doz
        • Sep 2005
        • 912
        what year is your 3100? if its 2001 or before you could always swap to 2001+ heads or 3400 heads/topend in general, but honestly 3100 heads/intake are far from poor. you could just put on some headers, bigger tb & cai/ram air, port matching/minor porting, and a crank scraper-that should give you some nice gains
