Block modifications
  • 01GPGT
    Curse you Red Baron!!!
    • Jun 2008
    • 214
    hmmm might be hitting a snag
    got a look at the bell hoising and i think i might weeken it if a try to clearance it for a starter. hmmm this kind of bites going to go look at one inperson tomarrow at a local yard and hold it up to a 3x00 block and see what i need to do. if wourse comes to wours i will have to use a RWD 3.4
    92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      If your using a manual trans you may be able to keep the drivers side starter if you can find the correct bell housing. 2.2L engines in S-10's used a driver side starter with the same bellhousing pattern. There was also that Camaro housing from the 80's that had dual starter pockets.
      • 01GPGT
        • Jun 2008
        • 214
        a T-5 would die a horrid death as soon as a put boost to it so i am going to use an auto trans. mainly the 700-r4 from the 80's camaro with a 2.8-3.1L
          Live life 3.7mi at a time
          • 4555
          The 93 f-body is also the same trans in a different case, just an FYI.
          Wasn't there a Trooper trans that had the dual starter pockets, or was that also their manuals?
          • 01GPGT
            • Jun 2008
            • 214
            good to know a bought the '93. was not 100% sure when it became the 4T60-E i know a 4T60 will work (non electronic)
              T=FWD(or technically with a fiero its RWD)
              L=RWD....
              4l60=/=4t60
                • 4555
                #22
                L=RWD....
                4l60=/=4t60
                t = transverse (so that makes Fiero correct)
                l = longitudinal
                  thats the more technical way of saying it(and correct according to GM), but usually when i explain it that way, i get a real confused stare...
                  • 01GPGT
                    • Jun 2008
                    • 214
                    #24
                    i know that i had a brain fart
                    so any 4L60 before it became electronicly controled
                      • 4555
                      #25
                      94 up is electric trans for the "L" designation.
                      • geoffinbc
                        • 5831
                        #26
                        You don't necessarily have to use the T5 from an S-10. Chevy used the same trans to bellhousing patter and Ford in the later years. I am not sure on all the details but a T5 from a Mustang or perhaps a T56 might be a possibility .
                        If an Auto is your choice then would a 4L60E from a 2.2L S-10 fit the bill? The starter is on the driver side. The only thing you would need is a controller and several companies have that covered.
                        • 01GPGT
                          • Jun 2008
                          • 214
                          #27
                          really? i did not know that. doese the 2.2 have the metric bolt pattern like the 660?
                          i can get a 4l60 for a S-10 cheaper then one from a camaro as well so this would be a win
                            • 4555
                            #28
                            Yes, same pattern.GM small corporate pattern.
                            • 01GPGT
                              • Jun 2008
                              • 214
                              #29
                              well hot damn. this makes it alot easier
                              • WrathOfSocrus
                                • Jan 2008
                                • 318
                                #30
                                Are the those transmissions the same as the 4.3 except for the bellhousing? I know later year auto's with the removable bellhousing look identical but i believe those are electrically different from the mid 90's ones. I was reading on s10 forum that the 2.2 auto is the 'little brother' of the 4.3 auto but wasnt sure what the differences were or what years it covered.
