95 GTP 5 Spd Swap and OBD 2 w/ 96/97 Engine..
    OldskoolGP's old GP that Ben bought is a 5 speed and runs on OBD2. As for the heater core lines, why not run rubber there and route them below the brake booster? That would give it a slightly cleaner look anyways. Oh, and as for the cam carrier gasket, just buy a new one. Old ones aren't too reliable. I changed to Mobil 1 on the 91 many many moons ago and my cam carrier gasket sprang a leak.
      • 9189
      i'll send the PDFs with the diagrams that way instead of using more 60V6 server storage...
      We are running out of room... I mean, right now we are sitting at just over 5GB for the entire 60V6 site, Ben is less than 1GB for WOT-Tech, and we are on a 40GB VPS.
        wait... i'm confused, so around 6GB used or around 6GB left?
          • 9189
          6GB used... With all the redundancy and databases and what-not, we are sitting at 17GB used out of the 40GB, but still not running out of room in the least. Over 600MB sits in the 1000+ images in the Photo Gallery.
          • 94GPGTP
            95 Grand Prix GTP
            • Apr 2007
            • 593
            I have yet to find them new seperate from a head gasket set.. Have you?
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            Drilled/Slotted Rotors
            White
            3" Magnaflow Catback
            90 Pontiac Turbo Grand Prix
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            230,000 mile Getrag 282
            Emissions Deleted
            Brand new Engine 1,000 Miles
            Fully Custom Built car
            • W41duvernay
              • Oct 2009
              • 13
              #21
              lighten rod option
              Sir,
              if you need a lighten rod, you may look at Wiesco #CH-5700ALLB-L8a.
              It weights 492 grams. Should help you keep the revs. They wanted racer
              costs at $610. It's originally for a Chevy 327 small journal applications. Do the clearance work on the block and get some custom forged pistons w/
              the Chevy pin .927", you'll have a nice strong bottom end for a nitrous, or
              turbo, or supercharger.
              • 94GPGTP
                95 Grand Prix GTP
                • Apr 2007
                • 593
                #22
                Robert,
                I printed out the sheets today and highllighted the pins that are the same description, location and color.. I only found 8 differences between the 2 C100 connectors.. If i explain it to you can you help me out on what whould need to be changed and so..
                thanks
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                • W41duvernay
                  • Oct 2009
                  • 13
                  #23
                  more rebuild options
                  For a rebuild kit for the 3.4 DOHC, look at Flatlander Racing. they want $500.
                  Throw in a set of forged pistons, for a nice bottom end for a turbo, nitrous, etc.
                    Sadly, no. But then again I don't like to drop engines in without looking at the cylinders, having the heads checked, ect. so a head gasket set would be in order.
                      Robert,
                      thanks
                      yeah, no problem, post em up here.
                      • 94GPGTP
                        95 Grand Prix GTP
                        • Apr 2007
                        • 593
                        #26
                        There is nothing wrong with these heads or anything.. i was burning the manifols bolts out that were broke and tried heating up the AIR fitting to get that loose and try to find a plug for it and when heating the AIR fitting i burned the cam carrier gasket out on the front so now i need to change it out.. i have reused one before and put a slightest film of gasket maker on each side to make a seal and never had one leak on me before.. But the one i took a picture of is a spare i have and its beond reusing.. the permadry so falling off so a reuse is not possible.. i may just pull the cam carrier off my 92 to reuse if need be
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                        • 94GPGTP
                          95 Grand Prix GTP
                          • Apr 2007
                          • 593
                          #27
                          OK hopefully i can make sense out of this..
                          96 has A1 and 95 does not
                          95 has A3 and 96 does not
                          95 has D5(f) and D5 and 96 only has D5
                          96 does not have a D5(f) listed
                          E1 on 96 is different than E1 on 95
                          96 has J2P and 95 does not
                          95 has K2 and 96 does not
                          95 has L1 and 96 does not
                          96 Description
                          A1-- Ignition feed from underhood electrical center #1 to stoplamp switch
                          J2P--Serial data signal-Class 2
                          E1--Ignition feed to powertrain control module and ignition system relay
                          D5--Transaxle range switch output to rear compartment lid release switch
                          95 Description
                          A3--Ignition switch "ign 1" feed to fuse block
                          D5(f)-- Transaxle range or park.neutral position switch output to remote control door lock reciever
                          D5--Transaxle range or park.neutral position switch output to remote control door lock reciever
                          E1--Engine oil level sensor output
                          K2--Ignition "3" feed to underhood electrical center #1
                          L1-- Battery fused feed- Maxifuse #2
                          Robert
                          New Rebuilt 3100
                          New Rebuilt 4T60-E
                          Exhaust
                          White
                          5 Speed Swapped
                          127,000
                          Spec Stage 3 Clutch
                          Emissions Deleted
                          • 94GPGTP
                            95 Grand Prix GTP
                            • Apr 2007
                            • 593
                            #28
                            Slight update here.. I got the engine and trans off the subframe.. Once that was off i got the harness off the engine.. Then i got the trans off the engine.. The subframe is ready to go back into the car so i can roll the car out onto a trailer thats going straight to the scrapyard.. Some pictures of the progress i was doing.. The engine and trans are set aside to get the subframe on the car once that is done i will toss the tranny in the trunk and away she goes..
                            Robert
                            New Rebuilt 3100
                            New Rebuilt 4T60-E
                            Exhaust
                            White
                            5 Speed Swapped
                            127,000
                            Spec Stage 3 Clutch
                            Emissions Deleted
                              you can ignore J2, it applies to 96 GPs and since you have a 96 lumina harness...
                              E1 on the 95 and F1 on the 96 are for the same function. switch the pin and its done.
                              not sure if the others need to be wired indivually yet, i'll check to see if they are wired somewhere else...
                                it looks like you'll need to play with the C200 as well...
