new member with few questions on a possible swap
  • goeagles
    • Feb 2010
    • 4
    HELLO guys i have a 1997 cavalier 4sp auto and trying to figure if any one has done a 3400 auto swap into a 3rd gen jbody ??
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    yup, 97 is a bit more work as you need to change dash harness and fuel tank etc.
    goto j-body.org there is a write up there
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • goeagles
      • Feb 2010
      • 4
      i read some of that write up but i think i can keep my oem gas tank. i also heard that maybe tranny bolts up to 3400 engine too
      • Weatheralls Auto
        • Dec 2009
        • 536
        Its the sending unit that needs changing, tank your good but i would go plastic if ya have urs out already.
        what engine in ur Cav ATM?
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
        • goeagles
          • Feb 2010
          • 4
          i have the silly 2.2 ohv and yeah is a auto 4spd tranny
          • Weatheralls Auto
            • Dec 2009
            • 536
            2.2 trans WILL bolt directly to 3400 or any 60*V6, it is the 2.4 that is odd.
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • goeagles
              • Feb 2010
              • 4
              has any one done this swap ? i heard is a pain to run the gauges
                I can verify the 2.2 bolt pattern first hand. I never changed my engine stand setting between rebuilds on a 2.2 from a 2000 Sonoma and a 3400 from a 97 TranSport.
                • Weatheralls Auto
                  • Dec 2009
                  • 536
                  Because you have a 97, you need to change interior harness to a 2000+ and use Bcm,
                  then gauges will work perfect.
                  I just installed a 3500 in my 3rd Gen Cavy this weekend
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
