can i swap a 95 3100 into a 99 malibu
  • yukon joe
    sixr
    • Mar 2010
    • 4
    can i swap the 95 into the 99? or even a 3400 without any problem ?
    • 9190
    A 3400 would be preferable obviously, and a pretty simple swap. But yes, a 95 3100 will bolt up to a 99 Malibu. There will be some small things to work out (mainly EGR related), but pretty simple overall. I'm almost positive someone was asking almost the exact same question sometime last week...
    EDIT: Nevermind, it was you... http://60degreev6.com/forum/f109/94-...bu-3100-t45960
      95 3100 is a small port POS... Not worth swapping if you ask me.
        • 9190
        But did the 99 Malibu get a large port or small port 3100? I thought only the GAs got the large port in 99, or maybe that was the 3400...
          Crap your right... the 99 malibu may be a small port... I thought they were 3400's by then though...
          Time for google to answer.... lol
          Your right... I was wrong... 1997 to 1999.5 L82 engine Notice 1999.5 for the year... lol, so really I'm half a year right
          Engines
          Years Engine Power Torque
          1997-1999.5 3.1 L GM 60° L82 V6 155 hp (116 kW) 185 lb·ft (251 N·m)
          1999.5-2003 3.1 L GM 60° LG8 V6 170 hp (127 kW) 190 lb·ft (258 N·m)
          1997–2000 2.4 L TwinCam LD9 I4 150 hp (112 kW) 155 lb·ft (210 N·m)
          2004–2005 2.2 L Ecotec L61 I4 144 hp (107 kW) 155 lb·ft (210 N·m)
