3.4 tdc out the top
  • 93vinx
    • 154
    3.4 tdc out the top
    is it possible to get the 3.4 out of the car though the tops i've seen posts that say yes and no, has anyone ever done it?
    vrrrooooooooooooooooom i need new exhaust
  • patgizz
    The Plaid Bandit
    • 1071
    ive done it both ways w/ trans.
    remove your AC pressure sensor on the LH frame rail and you will be OK to pull it out the top.
    • 93vinx
      • 154
      so i should pull the motor and trans(manual) and then put it back, what kind of car, motor and trans do you have. ?
      • 93vinx
        • 154
        the ac sensor, is the one under the air box?
        • patgizz
          The Plaid Bandit
          • 1071
          yes.
          both cars i did were auto. its easier to me to pull everything and swap the trans on the floor in front of me, but thats up to you. i did my 94 lumina from the bottom, and a 90 GP thru the top(3.1-3.4 swaps in both cases)
          • 93vinx
            • 154
            ok trans and mototr coming out sunday.
            • 93vinx
              • 154
              it s all out, tokk me bout 4 hours startesd cleaning new motor comes home tomm.
              • Anonymous
                Saw this too late-but I took my 3.4/5M out the top. I disconnected the AC from the belt drive, but left it in the bay with the lines hooked up. Basically I had to strip everything off the motor in order to get it out, even the exhaust manis.
                • dykz34
                  • Jan 2004
                  • 793
                  Did you leave the brake master cylinder in place?
                  • Anonymous
                    I had to unbolt it, then move it. So I used bailing wire to hold it out of the way, becuz the tranny wouldn't clear it. I left the lines attached like I did with the AC, but it had to be pushed a little.
                    • 93vinx
                      • 154
                      all i removed was the plugs , ac lines, clutch cables and a pressure sensor for the ac
                      • Anonymous
                        I pretty much stripped the motor while it was in the car just to make things easy, and the crap had to come off anyway. So when I had an hour or two after school, I'd pull as much as I could, and in a week, the motor was pretty much a bare long block with the tranny.
