Turbo Grand Prix 3500 swap
  • CNCguy
    replied
    The accessory terminal on the ignition switch would work but it will be on when you have the key to "accessory". If that is a problem, you could always wire in a normally closed relay and use the wire to the solenoid to "open" the contacts while the engine is cranking.
  • Jonpro03
    replied
    I take it nobody knows! LOL
    I'll just grab a line from the radio.
  • Jonpro03
    replied
    Where can I get a switched 12v that is switched OFF while cranking? I just need it to trip a relay. I want to get a source off of the engine harness but if I have to run a wire from the radio I will.
  • Jonpro03
    replied
    It lined up just fine, but I realized that I haven't put the motor mount on yet so that will change a lot.
    Last night the oil pan went away to get drilled/tapped and I finished up some loose ends on the engine harness.
    replied
    Probably a good thing, it's the correct diameter but just a little too short to work in the external trigger setup.
    Did you manage to get the trigger to line up using the 3500 crank pulley? all the rest of us swapped to a 3.1/3400 pulley to get the clearance we needed.
  • Jonpro03
    replied
    I should probably start another thread but FYI, a 3500 CPS will read the 7x wheel just fine. It even puts out a clean square wave.. (Cell phone pic)
    Nah, it's ok. I wasn't sure about that so I used the CPS off of the 3.1
    replied
  • Jonpro03
    replied
    Today I married the megasquirt harness with the TGP harness. I also installed the ECT that came in today and painted the UIM/LIM TB and valve covers metallic silver. I'll post pics later.
    replied
    well, yeah, the TCC apply circuit.
    apply 12V, TCC will lock.
    remove it, or break the connection via the brake switch, TCC unlocks.
  • Jonpro03
    replied
    Great, Does the trans need any input from the ecm to activate the tcc?
    replied
    jon, i think you're making it much harder than it is...
    if you take a look at the diagram, you'll see that the brake switch is a necessary part of TCC operation. whenever the brake is pressed, the circuit to apply the TCC is broken, so no more lockup.
    and what is this about engaging overdrive? the 4T60 has a VERY minimal set of controls from the ECM, and if you're at a high enough MPH compared to where the TV cable is positioned, it will shift into 4th regardless of ECM intention.
  • Jonpro03
    replied
    I found this documentation to controll the TCC with Megasquirt2 using the fast idle output to trip the solenoid.
    For example, if you wanted to use the FIdle output as a TCC control, and the accel LED as an indicator that the TCC is active, you would set:
    * FIdle (PM2):
    o Port PM2, enabled
    o variable = map < threshold = 75, hysteresis = 10,
    o AND
    o variable = coolant > threshold = 160, hysteresis = 10,
    o Power-on value = 0
    o Trigger value = 0
    * Accel LED (PM4):
    o Port PM4, enabled
    o AND
    o Trigger value = 1
    Example: Torque Converter Clutch Control
    Suppose you want to engage OD (overdrive) over 50 kPa MAP, and engage the LU (torque converter lock-up) clutch at 75 kPa MAP, provided temp is over 140 and RPM is over 2000. For a torque converter clutch control (TCC) using FIdle with 3 conditions (rpm > 1500, CLT > 160, map < 75), set:
    PA0 - Knk Enable:
    * rpm > 1500
    * coolant > 160
    and
    PM2 - FIdle:
    * map < 75
    * port0 > 63
    Then use the FIdle output to drive the TCC relay (if you have a relay board, you are all set). Not that you also need a 3/4 gear indicator switch and a brake switch in the external circuit:
    EDIT: megamanual won't let me copy the image of the TTC Control Circuit so here's the link to the webpage, the image is about 3/4 the way down the page. http://www.megamanual.com/ms2/spare.htm
    Is the brake switch already present on the harness or is that controlled by the TGP ecm?
    If so, it's as simple as:
    30 green/orange = TCC = B7 TAN/BLK
  • Jonpro03
    replied
    Question about the Transmission. What does it need from the ecm to run?
  • Jonpro03
    replied
    I finished the wiring harness diagram for the megasquirt swap, this setup is using GMDIS with an external trigger:
    Megasquirt = signal = TGP engine harness
    20 tan/yellow = intake temp = C22 LT GRN
    21 purple = coolant temp = C16 YEL
    22 blue = tps signal = C15 DK BLUE
    23 lght blue = 02 = A16
    24 green = CPS = D13 PPL/WHT
    25 gray = iac1 = A1 LT BLU/WHT
    26 gray/red stripe = 5v ref = C12 GRY
    27 white/blue strp = iac2 = A7 LT BLU/BLK
    28 red/white stipe = 12v = D17/C7 ORN
    29 green/red str = iac3 = A8 LT GRN/WHT
    31 orange/black = iac4 = A2 LT GRN/BLK
    32 gray/yellow = bank1 inj\ = D9 LT BLU (2 4 6)
    33 gray/yellow = bank1 inj/
    34 pink/black = bank2 inj\ = D3 LT GRN (1 3 5)
    35 pink/black = bank2 inj/
    36 yellow/black = ICM = C9 TAN/BLK
    37 orange/white = fuelpump = D7 GRN/WHT
    9 SENOR GOUND = C6 BLK/WHT
    10 = C5 BLK
    11 = C10 BLK
    12 = D4 BLK/WHT
    replied
    Damn... I still need to get a scope.
    After this thread, I had to dig out my Velleman handheld I bought several years ago when I was working on my standalone project on the Beretta. Not sure how many times I used it, but it still looks brand new, and even has the plastic film still on the screen! Too bad I don't have a 3500 to mess with.
