90 grand prix 3.1 swap in 3.4
  • BumpRacerX.com
    • Dec 2009
    • 86
    Hey gang,
    Have a '90 Grand Prix 3.1 liter with a blown motor. The engine I'm looking at is a '91 Grand Prix 3.4. Will the stock 4t60 trans mate up out of the '90? What about the wiring harnesses, ecu's, etc. From what I can tell they use the same engine cradles. What other items do I need to swap over?
    I've read quite a ways through the forums and found one guy that looked like he was running the 3.1 ecm to make it work.
    The next question I have is how much work is it to make the 3.1/3100 transmissions work with the 3.4 lq1? From what I can tell they are the same transmissions with different final drive ratios. We would like to use the 3.1/3100 transmissions in order to increase our holeshots.
  • Fierobuffoon
    • Aug 2010
    • 52
    they go together just fine, i put a 3100 into a cutty convertable, and it played well together.. Put the LQ1 into something lighter.. ive got a spare 3.1 you can buy..
    youd need the motor mount, trans mount/bracket between the engine and pass side, and the entire wire harness, to answer your Q plus the exhaust pipe
