Need help with Felpro part numbers
  • Arisaka
    • Oct 2010
    • 16
    I have a 1997 Chevy Lumina 3100 engine with a bad knock.
    I have a low mileage 1999 3100 engine to replace the bad engine.
    While the replacement engine is out.I want to replace the intake gaskets and head gaskets.
    Would somebody please provide Felpro part numbers for the gaskets I need.
    Thank You,Jimmy
  • 86FieroSEv6
    • Feb 2010
    • 527
    The Fel-Pro head install set is HIS9957PT2. If you plan to have the heads sent to a machine shop for prep then just remove the "I" from the part number to include valve stem seals. You will also need the ES72892 head bolt set. Be sure to clean out the head bolt holes and follow the torque procedure to the letter.
