3500 vvt beretta help.
  • Shane
    • Aug 2010
    • 121
    What is all involved in swaping the 3500vvt into a beretta and has anyone ever done it? What vehicles have that engine? I know it would be alot more work.
  • Z26-T
    • Apr 2008
    • 486
    a few people have done a 3500 swap, haven't heard of anyone doing a 3500 vvt... Personally I'd stick with a standard 3500. More aftermarket available and a lot less headache involved in the swap.
    • mickaz
      • Aug 2004
      • 350
      you need the harness and the ecm and the engine. you would need to have a tuner and need to splice some wires....for 24 more hp? not worth it. get a 3500 and get a cam....you will have a faster car anyways
      Mike 60degree addict.
      • Shane
        • Aug 2010
        • 121
        oh really thats the only diff is 24hp. ok then, i can pick up a 3500 from a wrecker for $4-500. what about the 3400 dohc?
        • Rootie524
          • Feb 2010
          • 543
          how do you know if it's vvt or not? i found this on ebay. is it the non vvt? http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
            • 9186
            That is non-VVT.
            • Z26-T
              • Apr 2008
              • 486
              car-parts.com is also good if you want to see if you can find something more local for pickup so you don't have to pay for the shipping. But that one on ebay is a pretty good deal.
              • Starglow
                • Jun 2011
                • 83
                That is non-VVT.
                How can you tell for sure?
                I'm looking for a 3500 to swap in a '99 Grand AM to replace the 3400 and I want to make sure I get the correct engine.
                BTW.... I found a 3500 out of a 2006 Malibu with the transmission still attached. Will that trans work in my GA so I can just do a complete engine/trans swap?
                I know I can re-use the exhaust manifold setup off my 3400, but how hard is it to locate the 3500 exhaust crossover pipe and heat shields as most salvage yard motors don't have them?
                Thanks in advance....!
                • Starglow
                  • Jun 2011
                  • 83
                  Here are some pics of the 3500 engine:
                    two easy ways to tell if a 3500 is VVT or not:
                    cam phaser sticking out of the timing cover
                    the UIM has a V shaped notch on the side opposite of the TB
                    either of those things give away a 3500 motor as VVT.
                    • CNCguy
                      Bisong eater :P
                      • 1017
                      Another giveaway is the thermostat and upper radiator location location. Instead of being near the TB, they are located near the water pump. Also, no EGR valve.
                      MinusOne - 3100 - 4T60E
                      '79 MGB - LZ9 - T5
                      http://www.tcemotorsports.com
